Ground Rod Versus Ground Plate? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 07:10 PM   #1
Ground rod versus ground plate?
I used to work with portable crushers run off a generator where either a ground rod was required or a ground plate (Ontario, Canada). We used a ground plate as it was less work to bury and unbury. 1) For a garage, can one put in a ground plate instead of a ground rod? If yes how deep. 2) I believe that ground rods may also be buried horizontally. Is this correct?
Janluthe is offline   Reply With Quote
Old 03-28-2012, 07:20 PM   #2
Rewards Points: 6,652
Why not do a Ufer.
Old 03-28-2012, 07:30 PM   #3
Haverhill Trade 1965
I would check your local codes. Some places want it grounded (bonded) to re-bar in the foundation. It may not matter for a garage but some codes are getting out of hand.
Duckweather is offline   Reply With Quote
Old 03-28-2012, 08:49 PM   #4
joed's Avatar
Rewards Points: 11,518
From ESAFAQ page.
Question
Can I use a ground plate instead of a ground rod?
Answer
Yes. A ground plate may be used as an alternative to ground rods for grounding any electrical service of less than 750 volts.
Rule 10-700.
Ontario Electrical Safety Code 24th Edition/2009.
Related Answers
6-15-7 Ground rods, number of
6-15-10 Installing ground rods in area of shallow bedrock
6-15-11 Ground plate beneath basement floor?
6-15-12 Number of ground plates required?
Question
How many ground plates does the Code require to be installed for grounding of a residential electrical service?
Answer
The Code requires that a minimum of one approved ground plate be used for grounding a residential electrical service.
Rule 10-700.
Related Answers
6-15-6 Ground plate in place of ground rod
Question
Is it permissible to install a ground plate under the basement floor slab for grounding a low voltage electrical service?
Answer
Yes. The code states that the plate shall be in direct contact with exterior soil at no less than 600 mm (24") below finished grade. Where the plate is buried below a basement floor, the basement floor can be treated as grade and the plate is to be located at least 600 mm (24") below the slab.
Rule 10-700 and Bulletin 10-11-X.
Related Answers
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 04:05 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
dimmer-aluminum ground along with existing copper ground. scottie Electrical 2 09-25-2009 07:43 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
