Ground Rod Placement Suggestions
I bought 2 ground rods I am planning on installing maybe tomorrow. Can someone please tell me the current regs for NEC 2008 on where I can place them? i.e. distance from the house, and distance from each other. Is 6gage wire still correct? Do I bond them together, then run one cable to the panel?
They are the rods that look like copper they call them 5/8 inch, however one of the is just a smidgen thinner (1/8 to 1/16 slimmer). Is there a limit to how far I can run the ground cable? The part of the yard I want to put them in would cause me to have about a 40 foot run for the ground cable. Thanks Jamie |
So the cable run would end up being about 40' but, would be within 10 feet or so of the house. Actually, I am not sure how far away from the house I should place the rods. Jamie |
You can also contact your town electrical inspectors office. Just ask for guidelines regs for the task you want to do. I have always put the ground rods closed to the house no more then 1 foot off the foundation. never hit the footing to the foundation that way. You also don't want to cause a tripping hazard or find it with you lawn mower. As far as putting 2 in (does what you are doing call for 2) like I said it depends on what your task calls for. I work for the railroad and when we put in the signal bungalows it calls for a ground grid. But putting a ground grid for a house would be a new one for me unless you have lighting rods I would think. I never put one for a house. Hope this helps.
John |
The reason I am putting them in is that I plan to upgrade my service to 200A, which will very likely happen during the winter months, here in Wisconsin, the ground get frozen pretty solid, and I can only imagine how hard it would be to get a rod installed in the winter months here. It is my understanding that it is now code to have 2 grounding rods installed for your electrical service, so my understanding is that they will either want to install 2 new rods when the service is upgraded or they will want to be able to verify that they have been properly installed. I just want to get the rods properly installed prior to winter so they are there and ready to go, and we don't have to mess with this in the dead of winter when we change the panel / upgrade the service. So does anyone know if 2 grounding rods (8' copper color rods 5/8 inch thick) is what is required in general for electrical upgrades? I may give the city a call on this and see if they can give me a quick answer to it without asking lots of questions. Since they won't even be used until later when I do the full upgrade - that will of course require a permit. But I don't really want to have to get a permit to just pound in a couple rods now that are not even going to be hooked up till later. Thanks Jamie |
Jamie |
Yes, 6' minimum between rods.
All righty then goes to prove you learn something new everyday. LOL.
john |
Grounding rods vary from location to location. It depends on the soil and who wrote the local code.
At my main home we only have to go down 6 feet since the soil is moist year round. At my vacation home we have to have 2 rods a foot apart and go down 12 feet because it is very dry. Even at that depth it is hard to get consistent grounding in some systems. One rancher had to go down 20 feet with 4 rods to get consistent grounding. He initially followed code but still had that "buzz" when touching metal appliances so he had more grounds put in and that worked. He was telling me that he would get good ground on rainy days and for a week or so after that but it would always get real bad in the late summer. |
I didn't think that anyone could set standards that were less than the NEC code. i.e. I thought a 6 foot rod was always illegal, am I wrong? Jamie |
It's been said many times here, but one more won't hurt. Ground rods and other grounding electrodes serve no purpose for the normal function of the electrical system, including short circuits. If you had no earth grounding means at all, your wiring would still work properly. We only use earth grounds to limit the voltage on the system imposed by lightning and other high voltage events *outside* of our system. |
I know that he also had the panel replaced a few months after that. He has a small fire in his wood furnace and destroyed some of his wiring. |
| All times are GMT -4. The time now is 06:44 PM. |
