Ground Rod Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2007, 11:43 PM   #1
I need tips for driving ground rods. What is the easiest method(s)?
I heard something about filling your hole with water as you go, but I only got part of the info--can anyone elaborate on this?
(I need 3 for the house I just bought. 1 is for the generator. The other 2 is for the panel, which was only tied to the cold water.)
capt2 is offline   Reply With Quote
Old 10-10-2007, 02:06 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Rotary Hammer and ground rod chuck is by far the easiest method. Water in the hole can help in some soil conditions.
A ground rod at the generator is debatable, if your transfer switch does not switch the dwelling service neutral then a ground rod is not necessary.
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 10-10-2007, 07:56 AM   #3
RippySkippy's Avatar
When you did the water and hole method, did you keep adding water while moving the ground rod up and down? I've done that with many since I don't have the rotary hammer set up. I usually get about 6 feet in this way, then finish with a sledge. If you do the sledge route, put your clamp on before smaking it...that way you don't have to fight the mushroomed head.
RippySkippy is offline   Reply With Quote
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Ground rod blues!!! ra_doliv Electrical 8 09-03-2007 12:48 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
