Ground Rod And Ground Wire Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 04:47 PM   #16
Mad Scientist
Since I haven't seen it mentioned yet, make sure you put the ground rod clamp onto the ground rod before you hammer it. The top of the rod will mushroom a bit and you won't be able to fit the clamp over it afterwards.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
electures (07-28-2011)
Old 07-29-2011, 09:29 AM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Use a little tape to keep the connector from sliding down the rod and into the ground. Also make sure the end is flush with the ground. It can't stick up.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-29-2011, 05:10 PM   #18
Very helpful everyone! So my box was a cutler hammer and had 2 bars for neutral that were connected. It was simple enough to disconnect them from one another and screw one directly to the main box metal to metal to use for ground. Excellent idea that saved me a little loot and made the box look cleaner than adding another bar.
Last question, how far away from the subpanel do you drive the ground rods?
mulltron is offline   Reply With Quote
