Ground Rod In Foudation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 03:44 PM   #1
ground rod in foudation
We are having part of our foundation replaced. The inspector told the contractor to make sure and have an electrician install a ground to the re-rod within the foundation. I have never heard of this. Our house is grounded on the back side by the electrical panel. This is not in the area they are digging the new footings.
lbonam is offline   Reply With Quote
Old 05-25-2011, 04:30 PM   #2
Licensed electrician
Rewards Points: 1,604
Sounds like your inspector is asking for a Ufer ground to be installed in the new footings. This can be 20' of rebar or #4 copper in the bottom of the footing in contact with the earth. This would need to be bonded to any other electrodes in the grounding system.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
