The Ground Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 09:04 PM   #1
the ground rod
can I install the ground rod outside the house?
amilcar947 is offline   Reply With Quote
Old 03-23-2011, 09:17 PM   #2
Rewards Points: 506
Yes...but if you have a dirt floor you could install it inside also.
What???
jlmran is offline   Reply With Quote
Old 03-23-2011, 09:20 PM   #3
Rewards Points: 1,016
Ground rods are usually installed outside the house. Maybe there is more to the question?
Old 03-23-2011, 09:33 PM   #4
Rewards Points: 506
With due respect: please justify the validity of your question. Otherwise you'll be categorized as a fisherman, and your bait is goofy questions.
Old 03-24-2011, 07:37 AM   #5
Rewards Points: 1,538
No need to kibitz him using the above words. Don't take the ball out of his court and don't put words in his mouth.
Old 03-24-2011, 07:40 AM   #6
Rewards Points: 506
My apologies. The respect offered in my comment was sincere.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
