Ground Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 11:41 PM   #1
ground rod
is there any code to where the ground rod should be any distance withing the main panel?
main water line is in the front yard. main panel is in the back.
ground rod in next to the main water line
jonfregoso is offline   Reply With Quote
Old 08-02-2011, 06:30 AM   #2
I can't find a required distance from the panel in the code, but close proximity is usual. Some areas require two rods, so check local code. The ground conductor from the panel to the rod shall be no smaller than #6 copper or#4 alum. The panel shall also be grounded to a mettalic water pipe at a point close to where it enters the house.
Old 08-02-2011, 07:49 AM   #3
Rewards Points: 6,652
The ground rod should be nearest to the meter or entry point into the home. How close is it to the main water line? My fear is that if you got a lightening strike, it could jump from the rod to the water line, and re-enter the home.
Old 08-02-2011, 08:23 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The NEC does not specify a distance. We generally keep it as close as possible to the service disconnect to reduce the amount of wire needed to connect to it. It can be next to the water pipe.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-02-2011, 09:00 AM   #5
Master Electrician
Rewards Points: 3,864
Do not use aluminum wire to the ground rods unless it is 18" or more from grade. Aluminum wire will deteriorate quickly when in contact with the earth.
brric is online now   Reply With Quote
Old 08-02-2011, 11:35 AM   #6
Electrical Contractor
Ground rods can be placed anywhere. If two ground rods are used they must kept apart at least 6 feet.
hpp58 is offline   Reply With Quote
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
