Ground Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 09:15 AM   #1
Rewards Points: 120
ground question
Our crawl space has a single incandescent bulb, which I often have to supplement with a trouble light, depending on what I am doing down there, so one of this weeks projects is to replace it with 4 cfl fixtures. The incoming power is NM, and the new lights will be run with THWN through EMT. Am I correct in thinking that since the source is NM, I need to run a ground wire inside of the EMT? I know that EMT can serve as a ground, but seem to recall that I cannot mix a wire ground and an EMT ground within the same circuit. No big deal, as I have a roll of green THWN as well, so I guess more a matter of interest than anything else. Thank you.
Old 12-30-2013, 10:32 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
As long as the groud wire from the romex is attached to the metal box that the conduit is attached too, you do not need a ground wire.
Since you have the wire, I would use it.
The Following User Says Thank You to jbfan For This Useful Post:
DexterII (12-30-2013)
Old 12-30-2013, 10:44 AM   #3
no problem running a second equipment grounding conductor through the emt. like jbfan, i too would run the wire if you have it. it isn't required but is cheap insurance in case an emt fitting isn't properly tightened or something like that.
itsnotrequired is offline   Reply With Quote
The Following User Says Thank You to itsnotrequired For This Useful Post:
Old 12-30-2013, 11:14 AM   #4
Rewards Points: 120
Thank you. Not sure where I picked up the doubt, but yes, was thinking about it while wrapping up a few other things this morning, and agree; may as well just pull a ground wire with the others, and call it a day.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
question on 240 wire size and ground for wall oven twobyfour2 Electrical 8 04-30-2011 07:13 AM
Question about sub panel ground Richo Electrical 17 04-25-2011 09:18 AM
Above ground pool cover question joeg679 General DIY Discussions 8 08-03-2010 04:41 PM
