Ground Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2008, 04:18 PM   #1
ground problem
Hi, I just bought a new surge protector for my computer and when I plugged it in the 3 pronged outlet in my room the green ground light on it started blinking. I told someone about this and they said my outlet isnt wired right and I dont have a proper ground connection. So I went to Lowes and asked them about it and they told me to buy a 3 light tester so I got one of those and when I tested the outlet it said open ground, then when I plugged the surge protector in, it said hot-neutral-reverse. So I was wondering how I can fix this in order to get it grounded correctly without having to pay someone else to do it. Thanks.
Andyh1 is offline   Reply With Quote
Old 08-12-2008, 04:30 PM   #2
Registered User
Termite's Avatar
Your tester reads open ground because the receptacle isn't grounded. Whether it is easy or not depends on whether or not there is a ground wire in the circuit's wire in the electric box. I'd suggest shutting off the breaker to the receptacle (use the tester to make sure it is dead). Remove the screws that old the receptacle in there. If there's a bare copper wire in the box (or green), you probably just need to attach it to the green screw on the receptacle. You might need to get a grounding receptacle if the old one is really old.
If there's no ground wire, things just got tougher.
Old 08-12-2008, 05:07 PM   #3
Rewards Points: 410
To add, depending on the age of your house and how recent any modifications, when you remove the receptacle you may be lucky and find you have the older style armored cable. Back in the day, the white & black wires were inside a metal sheath. The metal sheath is attached to the breaker panel & grounded, and any box it's attached to will also be grounded as long as it's metal. You may be in a situation they used the old armored cable having a metal sheath, but used plastic boxes (you're supposed to use metal boxes with that type of wire which grounds everything).
To ground, you'd have to figure out a way to connect the metal sheath of that wire to the receptacles green screw... I'm not sure how that's done or if there's something out there that lets you do it properly. Here's a picture of the older style wire, notice the metal "jacket", if that's the wire you have behind the receptacle chances are you only need to connect that jacket to the green screw but I don't know how to do it properly or if they make something that does it. I believe another name for armored cable is "BX". Also, this isn't the best picture as it has white, black, AND green older houses would have only white & black, and the sheath used as the ground (no green wire in it).
Piedmont is offline   Reply With Quote
Old 08-12-2008, 06:27 PM   #4
Electrician
If the AC/BX is pre 1950, then you cannot use the outer jacket as a ground, it must contain a bonding strip internally.
chris75 is offline   Reply With Quote
Old 08-12-2008, 09:44 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
just a note of clarification; the cable pictured above is not ac/bx, it is MC and the reason it has a green/ground conductor is becuase the sheath is not acceptable as a grounding conductor. There is no way to attach the sheath to make it a legal ground with the one exception of a quite new version of MC that has a bonding wire similar to AC cable.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
gfci problem - 120v between ground and neutral dave0419 Electrical 1 08-18-2007 01:01 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Ground Wire Problem ScubaRaven Electrical 11 06-08-2006 03:32 PM
