Old 07-14-2012, 09:43 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
in ground pool bonding
danpik, EXCELLENT write up. Thanks.
Old 07-14-2012, 10:21 AM   #17
E2 Electrician
stickboy1375's Avatar
I concur, that must have taken some time to write, but most helpful to the OP I'm sure!
Old 07-14-2012, 01:00 PM   #18
Thanks guys. That writeup was an evolution over several weeks this spring on the pool forum I am on. For some reason it seems like there was an unusually large amount of questions this spring about pool shocks (electrical). There was also a large amount of misinformation about grounding and bonding being thrown out there as well. I usually will not get into the specifics of how to do the bonding on the posters pools as I am not there to see them in person but, instead, do as you have and refer them to read the code on what is required. I wrote the explanation more to clear up the confusion on the difference between the two and the reasons both exist. It still amaizes me that some people think a ground rod stuck in the dirt will protect them. I also have fixed about 20 bonding issues on pools around here this summer due to handyman instalations. I had a toe to toe with one of them a couple of weeks ago about this very thing. I ultimatly blew him in to the code people in town for doing an unpermitted install on a pool.
danpik is offline   Reply With Quote
Old 07-14-2012, 01:32 PM   #19
It was a dark and stormy
Yoyizit's Avatar
Here's another.
What was the lowest voltage that you had a complaint about? Was it from a man (women and children are more sensitive)?
Thanks.
Above ground pool ground cover sheet. mae-ling Landscaping & Lawn Care 3 06-28-2012 08:27 PM
Exposed pool ground wire, can I just cut it? Drywallhelp Electrical 14 08-28-2011 05:25 PM
Bonding Pool Equipment - Conflicting Advice rickster18 Electrical 6 08-18-2011 06:21 PM
pool bonding question.? pjwinstalls Electrical 5 06-28-2009 02:32 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
