Old 11-23-2012, 08:53 PM   #1
Question
Ground outlet to telephone line?
I have an ungrounded outlet right next to an old-style four pronged telephone jack. With a temporary setup I get a good ground per my outlet tester when grounding the outlet via the grounding prong in the telephone jack. I want to use a 1amp AC/DC converter on this outlet, and I want it to be grounded. Can I take advantage of this nearby phoneline ground or is the wiring too small for a safe ground for this converter?
owmytoe is offline   Reply With Quote
Old 11-23-2012, 09:06 PM   #2
joed's Avatar
NO you can not. The telephone wire is probably only #22 or 24. Much too small to use for a power line ground.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
frenchelectrican (11-24-2012)
Old 11-24-2012, 12:54 PM   #3
NO you can't do that!
Not safe!
Warning, Danger, etc.!!!
Have an electrician pull a new wire from the panel and be sure the panel grounding is "up to snuff".
Billy_Bob is offline   Reply With Quote
Old 11-24-2012, 01:57 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
There is NO ground prong on a tel jack.
The Following User Says Thank You to Speedy Petey For This Useful Post:
mpoulton (11-24-2012)
Old 11-24-2012, 08:18 PM   #5
Some telephone blocks have as big as an 8 gage ground. Better check the size!
neo565 is offline   Reply With Quote
Old 11-24-2012, 08:22 PM   #6
TTW
TTW's Avatar
Yes, possibly where the service enters the house, but sure as heck not at a telephone jack! He's talking about an old 4 prong jack, sot a service entrance block!
TTW is offline   Reply With Quote
Tags
four prong, ground, outlet, phoneline, wiring
Ground Wire in Electrical Outlet Box - Where does it go? jgiannis Electrical 3 06-19-2012 03:12 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Ground to water line MikeKy55 Electrical 3 01-24-2011 09:03 PM
telephone line buzzing latinomusician Electrical 2 06-09-2010 06:54 PM
