-   -   Ground outlet to telephone line? (http://www.diychatroom.com/f18/ground-outlet-telephone-line-164480/)
owmytoe 11-23-2012 08:53 PM
I have an ungrounded outlet right next to an old-style four pronged telephone jack. With a temporary setup I get a good ground per my outlet tester when grounding the outlet via the grounding prong in the telephone jack. I want to use a 1amp AC/DC converter on this outlet, and I want it to be grounded. Can I take advantage of this nearby phoneline ground or is the wiring too small for a safe ground for this converter?
joed 11-23-2012 09:06 PM
NO you can not. The telephone wire is probably only #22 or 24. Much too small to use for a power line ground.
Billy_Bob 11-24-2012 12:54 PM
NO you can't do that!
Not safe!
Warning, Danger, etc.!!!
Have an electrician pull a new wire from the panel and be sure the panel grounding is "up to snuff".
Speedy Petey 11-24-2012 01:57 PM
There is NO ground prong on a tel jack.
neo565 11-24-2012 08:18 PM
Some telephone blocks have as big as an 8 gage ground. Better check the size!
TTW 11-24-2012 08:22 PM
Yes, possibly where the service enters the house, but sure as heck not at a telephone jack! He's talking about an old 4 prong jack, sot a service entrance block!
