To Ground Or Not To Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 09:30 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 66
To ground or not to ground
When installing a light switch, receptacle, light fixture, etc, do I HAVE to connect the ground wire to the ground (green) screw? Most if all of the times that I've seen other people's work, it's not connected. The ground is connected directly to the box, and since the device is also physically connected to the box, it too, is grounded that way. Is this grounding sufficient? I've always done it this way, but starting to wonder if maybe it's wrong, and I have to ground the box and still connect a wire to that green screw. The only time I do connect is if it's a chained fixture that has a ground wire going to the fixture, as the chain is not really a good ground on it's own.
From reading other posts it seems people do always connect the green screw to ground, but wondering if maybe this is code in US, while in Canada it may not be. From my understanding plastic boxes are more common in the states while rare here unless outside, so in that case you have to connect that screw.
It's something I just kinda realized while reading other posts, maybe I need to go back and fix some of this stuff.
Red Squirrel is online now   Reply With Quote
Old 10-14-2010, 09:37 PM   #2
The ground wire to fixtures should be connected, its for safety
jddavis is offline   Reply With Quote
Old 10-14-2010, 09:42 PM   #3
Mad Scientist
Some switches and outlets are designed to be grounded just by contact with the metal box, they are known as self-grounding devices. They'll have a metal clip thing on the screw holes, ensuring that the mounting screws are solidly contacting the mounting yoke. The typical devices with floppy loose screws and those little square plastic or fiber washers are not self-grounding and need the ground wire connected.
This is NEC, anyway. Dunno if self-grounding devices are legal by the CEC.
McSteve is offline   Reply With Quote
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
12v DC ground to chassis ground of a 120V appliance? pcampbell Electrical 12 02-17-2009 10:24 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 01:14 PM
