Ground In New Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 03:30 PM   #1
Ground in new Breaker panel
I am installing a new breaker panel, it is seperate from the meter panel so I assume this is considered a sub panel. Can I run a ground from the main panel and connect to the neutral buss in the new panel or do I have to have a seperate ground buss. Do I use the green screw and connect it in the new "sub Panel"?
lioninoz is offline   Reply With Quote
Old 01-31-2011, 04:24 PM   #2
Master Electrician
Rewards Points: 3,678
What exactly is it that you are calling a 'meter panel'?
brric is online now   Reply With Quote
Old 01-31-2011, 05:35 PM   #3
joed's Avatar
Rewards Points: 11,536
If the sub panel is in the same building you need to feed it with a four wire cable and separate the neutral and the ground.
Old 01-31-2011, 06:03 PM   #4
Rewards Points: 1,418
If the meter panel has no switch or breaker that would turn off your new panel then ground and neutral busses at your new panel would be interconnected (bonded) and you would not need a separate ground wire.
Old 01-31-2011, 06:29 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You need to supply more information ... but ... if the panel or enclosure your calling the "meter panel' has circuit breakers or fuses regardless of whether there is a main single throw breaker any panel load side of that panel is a non service panel or in laymens terms a sub-panel and you would run a 4 wire feeder to that 'sub-panel' if your sub-panel is located in the same dwelling your meter panel is attached. Neutral and ground would be separated.
A little more detail would help us get a clear picture of what your describing
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
breaker panel Ehren51 Electrical 3 01-20-2015 06:23 PM
sub panel grounding bcarl Electrical 4 01-23-2011 11:37 PM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
