#1 |
Ground / Neutral Bar Question
Hi All,
I just had a Square D QO box / breakers installed. I see that the electrician connected some neutral wires to the ground bar and some ground wires to the neutral bar. Is this normal?
Basement Demo started Jan 2012: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Bathroom demo started Feb 2013: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Licensed Electrical Cont.
This is a main panel. There is no neutral and ground bars. They both serve both functions.
If one were added to the panel then that would only be for grounds.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 |
Thanks for the quick reply!!
#4 | |
Ground / Neutral Bar QuestionQuote:
#5 |
Master Electrician
Ground / Neutral Bar Question |
#6 | |
#7 |
He dipped all 3 feeds into his noalox bottle. If you zoom in, you can see a dark gray substance
I made sure he used it.
| The Following User Says Thank You to Trucon01 For This Useful Post: | Rochsolid (12-09-2012) |
| Display Modes | |
| square d panel neutral bar question | pdxrain | Electrical | 7 | 11-28-2011 12:28 AM |
| Sharing Neutrals on the same phase | electro | Electrical | 30 | 08-12-2010 03:10 PM |
| general service panel question about ground / neutral | BlueBSH | Electrical | 3 | 03-17-2010 07:55 PM |
| GFCI feeing subpanel question | scott2332 | Electrical | 45 | 02-28-2009 04:15 PM |
| Sub panel grounding | sluggermike | Electrical | 27 | 11-11-2007 02:23 AM |
