-   -   Ground / Neutral Bar Question (http://www.diychatroom.com/f18/ground-neutral-bar-question-166013/)
Trucon01 12-09-2012 10:40 AM
2 Attachment(s)
Hi All,
I just had a Square D QO box / breakers installed. I see that the electrician connected some neutral wires to the ground bar and some ground wires to the neutral bar. Is this normal?
Speedy Petey 12-09-2012 10:43 AM
This is a main panel. There is no neutral and ground bars. They both serve both functions.
If one were added to the panel then that would only be for grounds.
Trucon01 12-09-2012 10:45 AM
Thanks for the quick reply!!
Rochsolid 12-09-2012 07:07 PM
Originally Posted by Trucon01
Hi All,
No penetrox on your main lugs
brric 12-09-2012 07:14 PM
FYI. While I use anti-oxidant on all aluminum connections, it is NOT required unless the equipment manufacturer or the wire manufacturer requires it. Square D does not require it's use.
Rochsolid 12-09-2012 07:20 PM
I also use it every time
Trucon01 12-09-2012 09:26 PM
He dipped all 3 feeds into his noalox bottle. If you zoom in, you can see a dark gray substance :) I made sure he used it.
