Ground Location and Wire Size
10K views 25 replies 8 participants last post by  HouseHelper
New member; first post. Thanks in advance for reading and responding.
Although I’ve read many posts here related to this subject, I’m still confused.
I have a rural property with 200A meter loop on pole. This includes Milbank socket and 200A Siemens load center (W0816B1200CT) w/ 200A main disconnect and feed-through lugs. Of course the neutral and ground are bonded together there and connected to driven ground rod.
Here’s where my confusion begins… I was told by one electrician that from the main to sub-panel(s), I could run triplex URD cable, and then at the sub-panel I could drive another ground and split the neutral and ground there. In other words, I didn’t need to run a separate ground wire from the main to the sub-panel. Several posts here (and a guy at the big box) however, seem to indicate that a separate ground must be run from the main to any sub-panel in addition to the phase conductors and neutral. Which is correct?
If I need to run a separate ground, then what AWG? I will be running to 2 separate sub-panels; one using 4/0-4/0-4/0 via the feed-through lugs and another using 1/0-1/0-1/0 via a 100A breaker in the main (or maybe a 2-pole lug kit). I assume the size of the ground wire is proportional to the conductor size, so what size for each run? Also, if I’m running a separate ground, do I need to drive another ground rod at each sub-panel or is the ground back at the main sufficient for everything? What about plumbing or gas lines? Can they just be grounded through the sub-panel back to the ground at the main? Would separate ground wires need to be sheathed or bare? I’ll be burying the cable in 2” or 2.5” PVC.
the code exception that allowed the 3 wire system has been removed. You are now required to run 4 wires no matter what. You may still need a ground rod at the outbuilding.
sch 40pvc is fine for underground, but your uprisers will need to be sch80. 4-1/0s and ground will fit fine in 2"pvc. And 4-4/0 and ground will fit in 2 1/2" pvc,but you might find it hard to pull and worth going to a larger pipe.
Equipment Grounding Conductors- are sized by table 250.122.
200a-#6
100a-#8
Can somebody confirm that I'm using the right table.
Thanks.
Regarding the ground size, is that for copper? I plan to run Al URD for the phase conductors and neutral. Can I run a copper ground in the same conduit or should I use Al for the ground as well? Isn't there some sort of chemical reaction between Cu and Al? I know the URD is sheathed, but over time is it an issue having unlike metals? If I use an Al ground wire, does it become 200A = #4 and 100A = #6? Does the ground need to be sheathed or can it be bare?
You indicated that I may still need a ground rod at the sub-panel location. What would the determining factor be for that?
#8 · (Edited)
Thanks.
Yes it was. 100A= #8 Cu or #6 Al, 200A= #6 Cu or #4 Al
Either. But Al is cheaper.
The chemical reaction comes when the two metal are in direct contact with each other. There is no direct metal connection between a bare copper wire laying on top of an insulated aluminum wire (or vice versa).
See above.
In conduit, copper or aluminum can be bare or insulated, though insulated is less likely to damage the other conductors during the pull if all 4 don't move as a group. It can act like a saw in the worst case scenario. Not always likely, but possible. In direct burial, either is allowed if insulated, bare copper is allowed, but bare aluminum is not. Bare aluminum cannot be in direct contact with masonry or the earth or where subject to corrosive conditions, and cannot be terminated within 18' of the earth. Personally, I'd just stay with aluminum...cost issues.
In general, if the sub-panel (feeder panel) is not in the same, attached building as the main service disconnect, it needs a ground rod(s).
Where do I split the neutral and ground
I now understand that I need to run a separate ground wire from the main to the sub-panel. I have installed a separate ground bar in the subpanel and driven another ground rod. I will tie the ground bar to the ground rod and any loads will also be tied to the ground bar.
My question is about the ground coming into the subpanel from the main. Since it's bonded to the neutral at the main, do I connect it to the neutral bus at the subpanel, or do I split at that point and attach it to the separate ground bar?
Thanks.
The ground wire from the main terminates on the ground bar in the sub-panel. Do not install any bonding strap or screw from the neutral bar to the sub-panel enclosure, or remove them if they are installed already. In the sub-panel, the neutrals and the grounds will be isolated from each other. Only in the service disconnect (the equipment that houses the first breaker after the meter) are the neutral and the grounding wires connected.
Thanks again. Seems like every time I get an answer, I think of more questions.
Regarding connecting phase conductors in the sub-panel. I will be running from a 100A double pole breaker in the main to a 100A main lug subpanel using 1/0-1/0-1/0 triplex cable. The neutral has a yellow stripe, so no problem identifying it and connecting properly at the subpanel. The two phase conductors are both black. Do I need to be concerned about which phase conductor is connected to which lug in the subpanel? For instance does the conductor connected to the left lug in the main panel have to be connected to the left lug in the subpanel or could they be connected on opposite lugs. There will be one 240V load at the subpanel (well pump). If they have to be connected the same, how do I tell which is which when both conductors are black? Remember that this is a triplex cable rather than separate conductors, so it's going to be hard to visually trace an individual conductor from end to end.
Thanks again.
#15 ·
Thanks again.
On a single phase system, no you don’t need to know which ‘hot phase’ is connected to which main lug in the sub-panel.
You mentioned you’re using a main-lug panel? You know that if this panel is in a separate building, it also requires a disconnect? You should be able to get a 100A breaker and a hold down kit for that panel. You would attach your 1/0 to the breaker and not to the lugs (backfeed the breaker).
You are running a ground wire too, right?
#12 ·
you also need a ground conductor.4 wires total.as for identifing,with no power on,tie neutral to a black wire,go to other end and look for continuity between one of the black wires and neutral wire.put some red tape on black wire at both ends.if wire is just coiled up and not installed it would be eaiser.
#18 ·
Thanks.
Yes, I'm running a separate ground wire. I got a main lug panel because from other things I've read, I was under the impression that if there were fewer than 6 circuits in the subpanel a separate disconnect wasn't necessary. In the subpanel I'll have a 20A double pole for my well pump and 2 - 15A 120V circuits for light(s) and outlet(s). Do I still need a separate disconnect?
Another 'new' question. How much of that pulling lubricant might I expect to use to pull 1/0-1/0-1/0 + #6 ground 150' through 2" conduit? Long 90 at main and maybe a 45 degree elbow about 1/3 of the way. How about to pull 4/0-4/0-4/0 + #4 ground approximately 200' through 2 1/2'' conduit? Guy at the big box said just dump maybe a quart into the conduit at the start of the pull and then just drag the cable through it. Is that how it's done or do I need to be applying it to the full length of the cable as I'm pulling it through. What test strength rope do you think I'll need to pull?
How clean does the cable need to be at the connection end? I'm assuming the lubricant is non-conductive. Any possibility of adverse reaction with that antioxidant stuff you're supposed to use on Al cable/wire.
#19 ·
Lemme see... I bought one of the 1 quart-ish sized bottles years back when I was pulling wire for a pool with a run that was around 100'. I didn't use very much. That was just 1 cable of 10-2 UF. I was generous with the stuff, filled the end of each pipe before I pulled through.
Same bottle, I used it for my 35 foot run of 3 1/0 conductors plus 2 runs of 10/2 UF. I had all the conduit assembled and placed in the trench and pulled everything through from one application of coating the inside of one end of the conduit. The wires were all covered pretty well.
I wouldn't worry about interfering with the conductive grease... You're getting this stuff on the insulation, and you're cutting off the insulation where the conductive grease will go.
#21 ·
Oops, sorry LHB Texas, I guess I thought you were going to have more circuits on that panel. Better to error on the side of safety. My bad.
Cowboy is correct, you can have up to 6 breakers be your disconnects.
#22 ·
Another question...of course. Actually, two.
I am going to wire an outdoor outlet on the pole where the meter and main are located. At the main, the ground and neutral are bonded of course. Do I ground the outlet to the bonded neutral/ground bus, or for the outlet only, do I need to install a separate ground (say a screw in the cabinet or a small ground bus bar) and then tie that to the ground rod I've driven at the pole?
Next question. I've read several posts here and several articles elsewhere. I tried to do those neutral load calculations, but they're over my head. I've asked an electrician, a couple big box guys, a guy at the electric supply store, and the guy from the rural coop that brought in power to my property, about the size of the neutral I need to have. Can't seem to get a consistent answer. What size neutral do I need? I was going to run 4/0-4/0-4/0 + #4 ground from main to house ~ 170'. I'm figuring 200A load center at the house, but don't expect to ever come close that. My calculations come out to less than 125A. Anyway, I picked up the URD at Elliott Electric thinking I was getting 4/0-4/0-4/0. By the way, I had to hunt around to find that size. Should have looked a little closer before I left, but I ended up with 4/0-4/0-2/0 instead. The reason I'd gone for the bigger neutral was because of the different answers I kept getting about what size it needed to be. I figured too small is bad, so if I go with the big stuff, I couldn't go wrong, but now I have the 2/0 neutral and I'm ready to start pulling cable tomorrow. The Elliott guy said that's what everybody uses. Obviously despite the fact that I said 4/0-4/0-4/0, it didn't register. He heard "4/0" and "URD", and just assumed 4/0-4/0-2/0. The coop guy said 2/0 neutral should be fine. The electrician said 4/0. The big box guys were split. I'm thinking that since the 4/0-4/0-2/0 is so common and the 4/0-4/0-4/0 isn't, the smaller neutral is probably okay and what's usually used around here. So after all that, the question is... will I be okay with the 2/0 neutral? I won't have any atypical loads. I'll be using propane for heat, water heater, stove & oven. I really don't want to have to postpone the work to hunt for different cable if I can avoid it. I've taken time off and rented a mini-excavator to trench.
Thanks.
#23 ·
I kinda like a full size neutral, only because I don't have to do the calculation. Now with small sizes it tends not to be a big matter but once you get to large wire it's pricey. The code allows you to down size your neutral, because it only carries the difference between the two legs. which could be quite low. the common size will probably meet all but a few situations. You could do the calc for fun, but it'll be ok.
#24 · (Edited)
How about grounding the outlet in the main box? Need the separate bus bar? Also, while lying in bed thinking about all this I realized that the ground lug in the main is already connected to the ground rod, so where am I going to connect grounds going to other subpanels? There's only one lug and it's being used. Do I just use the bonded common/ground bus for ground when coming off the main? I don't think it's big enough for my #4 ground wire. Are you allowed to double lug a ground? I'm thinking nothing can ever be double lugged anywhere.
Also, I was going to run the 4/0-4/0-4/0 + #4 ground in 2 1/2" or 3" PVC. Can I get away with running the 4/0-4/0-2/0 +ground in 2" instead. That would sure make life easier.
#26 ·
The receptacle at the main will have the neutral and ground connected to the same bus bar... at that point, they are the same. The ground for the subpanels will also connect to the same bus, and #4 should fit without a problem.
The 2/0 neutral should be just fine. Remember, the neutral carries only the unbalanced current between the two hots, so in a perfectly load balanced panel, neutral current = 0. You will never achieve a balanced load in a residential panel, but as long as the loads are spread as evenly as possible across the two hot legs, you will be fine with the reduced size. If you use the 2.5" conduit, it will be easier to pull through any LB fittings.
In my opinion, the 1/0 run is oversized for the loads you specified. I would do it using 2/2/2/4 mobile home feeder on a 70A breaker.
