Ground On Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 09:28 AM   #1
Ground on light switch
My house was built in 1992. I find that the light switches are not grounded. But the books I am reading all show a ground terminal on a light switch.
These are plastic boxes, not metal.
When did grounded light switches come into use?
Thanks.
bw777 is offline   Reply With Quote
Old 02-17-2011, 09:39 AM   #2
Registered User
Termite's Avatar
I know it has been in the code since 1999...Can't say before that, as I don't have an NEC that old. Whether it was code or not, it would be a good idea (and relatively inexpensive) to get grounding switches in there and get that ground landed on them.
Old 02-17-2011, 12:51 PM   #3
One quick question-- Are these switches plastic? I have seen double insulated switches that do not need to be grounded as they have no conductive parts that could become energized. Maybe you started with this switche and as they failed someone put regular switches in without using the ground.
SparkandArc is offline   Reply With Quote
Old 02-17-2011, 05:25 PM   #4
Registered User
Termite's Avatar
NEC 404.9(B) does not exempt any type of switch mounted in a plastic box. So if it is in a plastic box, it in fact is required to be grounded. I'm citing the '02 because that's what I've got handy right now.
Many, many, many electricians fail to ground switches in plastic boxes. I bet I write it four or five times a week.
Old 02-17-2011, 06:02 PM   #5
I think you misunderstood my post. I was talking about plastic Switches, not plastic boxes. If the yoke on the switch is plastic and there is no possible way of any of it becoming energized,( exept internal connections and termination screws) then it does not need to be grounded. They would have to be listed as being Double Insulated. 250.114 Ex
Old 02-17-2011, 06:05 PM   #6
Electrical Contractor
kbsparky's Avatar
Grounding of metal-strapped wall switches has been a requirement since the 1970's.
-KB
Old 02-19-2011, 10:26 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
When I moved into my house, built in '98, the misses wanted all the switches changed to decor style. When doing so, I found many of them to be plastic yokes, by Eagle Co. None of them had a ground terminal. Thankfully the installer didn't cut the ground wire short, but rather just pushed it to the back of the box.
Kyle
Light will now switch off Manjo62 Electrical 3 02-10-2011 12:59 PM
Hi, new here and have a question about light switch in bathrooms Tazznum1 Electrical 2 01-26-2011 09:31 AM
adding second light from a switch agsurfer Electrical 3 09-10-2010 01:01 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Adding second light switch to an existing light TexasEd Electrical 7 08-15-2008 07:22 PM
