Ground On Kidde I12060 Fire Alarm - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 08:50 PM   #1
Ground on Kidde i12060 fire alarm
we are remodeling an rental and have retrofitted hardwiring for smoke alarms. However we bought Kidde i12060 alarms that have White, Black, and Red; no ground. What do I do with the ground wire from my 12 gauge romex wiring?
Steve Burke is offline   Reply With Quote
Old 01-12-2010, 08:53 PM   #2
Inspector/Instructor
codeone's Avatar
Is your cabinet metal or a plastic?
This was a brain blip.
codeone is offline   Reply With Quote
Old 01-12-2010, 08:55 PM   #3
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
The smoke detector's made of plastic. Therefore there's nothing to ground. Plastic does not conduct electricity.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 01-12-2010, 08:55 PM   #4
codeone's Avatar
These type alarms do not use a ground because of the plastic housing. Still tie your grounds together from one alarm box to the next and just fold up into the j-box.
Old 01-12-2010, 08:58 PM   #5
Yikes you guys are fast...and thanks. i have three alarm. the first two will have grounds tiied together, the last in series will have the end tucked inside the plastic box without connection. Going to do this now.
Old 01-12-2010, 09:05 PM   #6
Magnettica's Avatar
Rewards Points: 150
That's right, plastic box, plastic device, no worries.
If something cannot conduct electricity there's no sense in grounding (bonding) it.
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 08:09 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 09:07 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
