Ground Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 09:49 AM   #1
sweaty
Rewards Points: 276
Ground Generator
I just bought my first generator (Generac 5500W) this morning, planning for Sandy's power outage.
The manual says I need to ground it. Is this really necessary? Do people usually do this? Or is it just a lawyer-generated instruction? If necessary, how do I do it? I have no ground rods.
I'm putting it in a shed about 40 feet from the house and run extension cords, but they have no GFCI protection.
sweaty is offline   Reply With Quote
Old 10-29-2012, 09:54 AM   #2
Rewards Points: 6,652
Yes, you must ground it. If there is ever a short to the chassis, or at one of the plugs, it will kill you.
40 feet is a long way for a bunch of extension cords.
Old 10-29-2012, 11:22 AM   #3
Rewards Points: 3,130
Little late to be working on this, don't you think? Did you happen to buy any gasoline? You're going to need quite a bit. What do you intend to power?
Old 10-29-2012, 01:11 PM   #4
Julius793's Avatar
I assume the OP has a portable generator if that's the case the chassis is usually factory bonded to neutral to clear faults. Now to the OP can you give us a model #?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following 3 Users Say Thank You to Julius793 For This Useful Post:
brric (10-29-2012), jrclen (10-29-2012), mpoulton (10-29-2012)
A discussion on the Proper grounding for portable generators Stubbie Electrical 41 07-05-2012 10:15 PM
generator neutral and ground connections soma Electrical 14 12-19-2011 01:24 AM
Portable Generator Electrical Ground Earnie Electrical 35 01-18-2011 04:53 PM
Generator - stand alone feed circuit help? FussyBob Electrical 5 12-13-2010 10:15 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
