Ground-fault Circuit Interrupter Duplex? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 01:34 PM   #1
Ground-fault circuit interrupter duplex?
Does any one make a GFCI duplex that has a recessed test button?
When I plug something in to my Leviton GFCI duplex I usually hit the test button and then have to hit reset. It would be nice to have a GFCI that has a small recessed test button.
Guido is offline   Reply With Quote
Old 02-19-2010, 11:04 PM   #2
How recessed do you need?
The Cooper GFCI seems to have buttons that are slightly recessed.
http://electrical.hardwarestore.com/...et-102967.aspx
But otherwise, best bet would be to just go to your local hardware stores and see what's available. Usually big box stores will carry more than just one name brand of electrical outlets.
HooKooDooKu is offline   Reply With Quote
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
wiring a arc fault circuit breaker mikebjohnson Electrical 20 05-01-2011 11:21 AM
In praise of the Ground Fault Circuit Interrupter. Bigplanz Electrical 16 07-12-2009 03:43 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 10:56 AM
4-way circuit with 9 duplex receptacles crecore Electrical 7 09-01-2006 09:39 PM
