Ground From Extetior Meter - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 06:00 PM   #46
Rewards Points: 774
Originally Posted by stickboy1375 View Post
you also have to keep in mind that not every state has adopted every new code, Connecticut is still on the 2005, which I love, but it can make it tricky to give accurate advice to someone on the 2011 NEC.
Believe me Washington DC was 3 codes back at one time. I always try to preface something about depending on local codes. Typically DIY'ers are not in a position to argue with some inspectors that seem to write their own code and from our couches there is nothing we can do about that
Know A Little is offline   Reply With Quote
Old 11-10-2013, 06:04 PM   #47
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Try living in New Jersey. New work is the 2011 NEC with amendments. Rehab work is the 2008 NEC. But we still use the 2005 NEC for some of 210.8 gfi requirements for new and rehab. Then we have the UCC. A lot of contractors don't understand it either. And some inspectors as well.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-10-2013, 06:07 PM   #48
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Not IRBC ?? or IRC ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 11-10-2013, 06:07 PM   #49
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I work in multiple states and counties, always makes for a fun adventure….
Old 11-10-2013, 06:12 PM   #50
Rewards Points: 774
We work in multiple states and the District as well, luckily for 80% of what we do codes are not an issue.
Old 11-10-2013, 06:13 PM   #51
electures's Avatar
Oh. We use that as well.
Old 11-10-2013, 06:14 PM   #52
E2 Electrician
Connecticut as well…
Old 11-10-2013, 06:20 PM   #53
Rewards Points: 516
i have only seen the book once but have done some lookups ... what i understand the IRC has the NEC in it .. but the heading numbers are different/changed ....language the same
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 04:37 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
