Ground From Extetior Meter - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 07:31 PM   #16
Rewards Points: 6,652
Originally Posted by djlandkpl View Post
I clicked on the inspectapedia link and my virus program went nuts. Says the site is known for malicious content.
Your Virus program is giving you false positives. The Inspectapedia link was for reference only, not to be taken as the law, as some seem to do around here.
Old 11-09-2013, 08:11 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by gregzoll View Post
The answer is that it all has to do with why there is a grounding system in place on today's electrical system.
OK, but those links have NOTHING to do with the grounding electrode system. Only an equipment ground.
Here, maybe this can make it clearer for you http://www.pfeiffereng.com/Principal...0Grounding.pdf
No thanks. I'm good.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
Know A Little (11-09-2013), Philly Master (11-10-2013), stickboy1375 (11-09-2013)
Old 11-09-2013, 08:40 PM   #18
Rewards Points: 774
The most important aspect of grounding has NOTHING to do with the grounding electrode conductor, the physical connection to the dirt, if it did planes would be screwed! And those living on granite mountains would be as well (screwed)
It is bonding and the assurance everything in the facility is properly grounded/bonded and that the grounded conductor/neutral is free of grounds/shorts to ground, downstream of the main service neutral to ground bond.
Earth COULD CARE LESS.
Know A Little is offline   Reply With Quote
The Following 5 Users Say Thank You to Know A Little For This Useful Post:
brric (11-09-2013), danpik (11-10-2013), Philly Master (11-10-2013), Speedy Petey (11-10-2013), stickboy1375 (11-09-2013)
Old 11-10-2013, 01:15 AM   #19
I really hope that you are either kidding, or do not have a clue. You may want to stop while you are behind Know a not, as you should now be known.
I am sorry to state this, but I know a little bit more about how the systems work for not only electrical distribution in a home, but also on board a ship, and yes, I do also know how the electrical and other systems inter-work on a plane.
Try you might Know a little, but you failed big time on trying to come off as a smart a**.
Old 11-10-2013, 06:19 AM   #20
K A L is actually a really, really smart ass. In a very literal sense.
brric (11-10-2013), Philly Master (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 07:00 AM   #21
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
RIDDLE me this Batman :
C/P from internet ..
It never ceases to amaze me how the train of thought that ground fault current wants to go to earth is still even a thought. But the reasons are old habits never die easy, and there are several books on the market, by major publishers, that still teach this. With that in mind I can see this train of thought will still be passed on.
Simple Ohms law will reveal the amount of current that the earth and the connection to earth, how much current can flow.
Lets say you have 120 volts and the resistance of the earth is 20 Ohms: 120/20 = 6 amps of current flow. If that is connected to a 15 ampere breaker, that will not trip that breaker.
BTW - We have measured many grounding connections around here and the average is around 70 Ohms. 120/70 = 1.7 amperes of current flow
Theory: All electrons that leave the source (battery, transformer, generator, etc..) want to get back to the source. The electrons will travel every available path, regardless of the resistance. So some will travel the earth path, but most will follow the path of 'least resistance', which hopefully will be the intended path.
Mike Holt's Theory book is very good for electricians, and has good illustrations that we can relate to on an everyday basis.
To the ones interested in learning the NEC, if you are studying the code, that is great, but you should also be studying theory, this will greatly enhance your understanding of the code as well.
Pierre
Why then for a WATER pipe ... is wire size get bigger with the amount of amps of the service .... but the ground rod never needs to be bigger than #6 ???
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following 3 Users Say Thank You to Philly Master For This Useful Post:
Know A Little (11-10-2013), Speedy Petey (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 07:09 AM   #22
Rewards Points: 516
2011 NEC CODE
250.4 General Requirements for Grounding and Bonding.
(5) Effective Ground-Fault Current Path. Electrical equipment and wiring and other electrically conductive material likely to become energized shall be installed in a manner that creates a low-impedance circuit facilitating the operation of the overcurrent device or ground detector for high-impedance grounded systems. It shall be capable of safely carrying the maximum ground-fault current likely to be imposed on it from any point on the wiring system where a ground fault may occur to the electrical supply source. The earth shall not be considered as an effective ground-fault current path.
I rest my case .......
The Following 2 Users Say Thank You to Philly Master For This Useful Post:
Know A Little (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 07:45 AM   #23
Rewards Points: 774
Greg, I am not here to argue with you regarding grounding or any other subject for that matter. I have explained to you before my credentials regarding grounding and grounding issues. That you have a vast experience in DIY'ing and reading is impressive. But on this subject not only are you misguided you are FLAT OUT DANGEROUSLY WRONG.
If you can WITHOUT a link to misguided websites explain to me logically, mathematically and supply a one line that shows how your beliefs on the Earth important role in grounding works I will take a look.
Until then you really need to cool your jets on this issue. Lastly how or why do you feel it necessary to attack me personally, at no point have I attacked you lack of knowledge on this subject with personal attacks?
The Following User Says Thank You to Know A Little For This Useful Post:
Old 11-10-2013, 07:45 AM   #24
Licensed electrician
Rewards Points: 1,766
See the following regarding why the ground needs to be there: http://inspectapedia.com/electric/El...Inspection.htm It is not there just for Lightning strikes or surges.
After starting to read that link it is clear that no distinction is clearly made between the function of the GEC and EGC. Both are mentioned in the same paragraph even though they serve entirely different purposes.
Given the proper bonding between the EGC and the neutral a breaker will trip properly without a ground rod.
Here is what the NEC says about system grounding and it's purpose.
(1) Electrical System Grounding. Electrical systems that
are grounded shall be connected to earth in a manner that
will limit the voltage imposed by lightning, line surges, or
unintentional contact with higher-voltage lines and that will
stabilize the voltage to earth during normal operation
Here is a section concerning EGC's and equipment grounds.
Old 11-10-2013, 07:49 AM   #25
Think of the issue this could cause for boats if they needed ground rods. Blub Blub.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
Know A Little (11-10-2013), Philly Master (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 08:01 AM   #26
Rewards Points: 50
Mr. Greg is so way off target as I'm sure the electrical professionals on here agree. Learning how to install an intercom system in a Navy ship, buying DIY residential electrical books from HomeDepot, researching bogus internet websites about how electricity works; make an arm-chair electrician filled full of erroneous, faulty logic. I think we all know to whom I'm talking about. On one side, it's dangerous to provide such flawed rehetoric to those who are clueless about electrical work. On the other hand, I actually find it amusing at how one's narcissistic, fantasy world of electricity corrupts DIY'ers projects. I just hope they don't take his disastrous advice. 50% of the American public have no clue about electricity, 49.05% think they do. .95% actually do -- they are called electricians!
NotaDIY/Pro is offline   Reply With Quote
The Following 3 Users Say Thank You to NotaDIY/Pro For This Useful Post:
djlandkpl (11-10-2013), electures (11-10-2013), Philly Master (11-10-2013)
Old 11-10-2013, 08:12 AM   #27
I have to say, Greg is not a dumb guy, which is why I am so surprised he is not conceding this one.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
electures (11-10-2013), Know A Little (11-10-2013)
Old 11-10-2013, 08:18 AM   #28
Rewards Points: 50
I'm sure Mr. Greg is competent at something......... it's just not electricity. (I've seen his past advice) When he is on target, it's usually something a 5th grader could figure out. His arrogance is overwhelming with his dream-land electrical advice. Just an observation -- heck he is probably a great guy outside of this forum. He's just a bit misguided.
Old 11-10-2013, 08:23 AM   #29
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The Following 3 Users Say Thank You to k_buz For This Useful Post:
danpik (11-10-2013), HouseHelper (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 08:25 AM   #30
Rewards Points: 774
I agree and OVER GROUNDING will not hurt. I have been on sites with power quality issues on the 12th floor of a high rise and the Electrical Engineer and installing contractor want us to test the Earth resistance of their system and as they add additionally ground rods, debating a triad or square lay out.
All that additional copper in the Earth actually helps out miners, smelters, supply houses and contractors. Never solves the power quality issue.
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 04:37 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
