Ground From Extetior Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 03:33 PM   #1
Rewards Points: 24
My neighbor just accidentally cut the ground wire from the meter to the ground rod. Can the be spliced back together or is it best to have it replaced. Is there any safety issue until it's fixed
Roger0205 is offline   Reply With Quote
Old 11-09-2013, 03:48 PM   #2
Licensed electrician
Rewards Points: 1,630
It will be cheaper to replace it that having someone Cadweld or put an irreversible splice on it.
The only danger would be if you had a surge or lightning strike until it is repaired.
Old 11-09-2013, 03:54 PM   #3
Rewards Points: 24
Thanks. Exactly what I was thinking
Old 11-09-2013, 03:56 PM   #4
Electrician
Rewards Points: 150
It is best to have it replaced. Cadweld is acceptable. I'm not sure about split bolts.
Surge protectors may be rendered completely ineffective. The house may be unprotected from lightning. Safety is compromised.
Oops, Jim said it faster, and better.
Glennsparky is offline   Reply With Quote
Old 11-09-2013, 04:26 PM   #5
Rewards Points: 6,652
See the following regarding why the ground needs to be there: http://inspectapedia.com/electric/El...Inspection.htm It is not there just for Lightning strikes or surges.
Old 11-09-2013, 04:33 PM   #6
Master Electrician
Rewards Points: 3,874
That is TOTAL BS. I'll bet you $100.00 I can connect a conductor directly from a breaker to a ground rod and the breaker will NOT trip. The current must go back to the source, not the earth.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
Jim Port (11-10-2013), Philly Master (11-09-2013)
Old 11-09-2013, 05:03 PM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Totally wrong information… typical though. Ground rods are installed for lightning strikes, not to facilitate the operation of an over current protection device….
The Following 6 Users Say Thank You to stickboy1375 For This Useful Post:
brric (11-09-2013), danpik (11-09-2013), electures (11-09-2013), Jim Port (11-10-2013), Philly Master (11-09-2013), Speedy Petey (11-09-2013)
Old 11-09-2013, 05:43 PM   #8
Rewards Points: 774
AND, accidental faults between the primary and secondary at the utility transformer.
Know A Little is offline   Reply With Quote
Old 11-09-2013, 05:45 PM   #9
Rewards Points: 774
What do the kids say OMG....THis guy is so far off the mark
Why we need electrical grounding
The grounding system at a building provides an easy path for electricity to flow to earth should a problem, such as a short circuit, occur.
Allowing current to flow to earth through the ground system helps assure that a circuit breaker will trip or fuse will blow should a problem occur. Properly operating these overcurrent devices help prevent fire and shock.
Should an electrical fault occur where no ground path is present, the electrical potential is just sitting there waiting for a person to come along, touch some component of the system, and by accidentally providing a path to earth through their body, receive a burn or potentially fatal shock.
Old 11-09-2013, 06:30 PM   #10
Time to repost this video again.
http://www.youtube.com/watch?v=EQiMr...layer_embedded
http://hyperphysics.phy-astr.gsu.edu...ic/bregnd.html
Old 11-09-2013, 06:38 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I agree. Mostly inaccurate BS. It's a shame so many folks rely on sites like that.
Speedy Petey is online now   Reply With Quote
Old 11-09-2013, 06:40 PM   #12
WHAT AT ALL does this have to do with the OP or grounding electrodes????
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
electures (11-09-2013), stickboy1375 (11-09-2013)
Old 11-09-2013, 06:58 PM   #13
Rewards Points: 50
Wow! I've been "lurking" this forum for some time and after this, I couldn't resist joining. And all I can say is OMG at some of the stuff that is mentioned about electricity on here. It's a wonder most folks don't burn their house down! But I must also add, the professional electricians on here are very impressive with their advice. However, Mr. Greg IC3 (Interior Communications Electrician - on Ships, Enlisted E-3), dude, you should really stick to hooking up home stereo systems / telephones and leave the electrical advice to those that know their stuff. Your video and hyper-links make no sense to the topic at hand and are simply worthless nonsense period. (as mentioned by others). Just some friendly advice that will more likely be taken as a stab. Sorry, dude. Other than that, just had to opine. Interesting forum.
NotaDIY/Pro is offline   Reply With Quote
The Following 4 Users Say Thank You to NotaDIY/Pro For This Useful Post:
djlandkpl (11-09-2013), electures (11-09-2013), Philly Master (11-10-2013), stickboy1375 (11-09-2013)
Old 11-09-2013, 07:19 PM   #14
Rewards Points: 34
I clicked on the inspectapedia link and my virus program went nuts. Says the site is known for malicious content.
Dan
djlandkpl is offline   Reply With Quote
Old 11-09-2013, 07:30 PM   #15
The answer is that it all has to do with why there is a grounding system in place on today's electrical system. Here, maybe this can make it clearer for you http://www.pfeiffereng.com/Principal...0Grounding.pdf
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 04:37 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Sub Panel Grounding Question. RobertS Electrical 63 02-27-2008 01:50 PM
