Ground Electric Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 04:26 AM   #1
ground electric panel
Neutral bus not bonded to the panel enclosure
victormtino is offline   Reply With Quote
Old 09-26-2010, 07:06 AM   #2
Not sure what your question is?????? In the main panel, the neutral and ground buss are connected together and to the panel, and to a ground electrode buried in the ground. In a sub-panel, the ground buss is connected to the panel and a grounding electrode. The neutral buss is NOT connected to the panel or the ground buss.
Old 09-26-2010, 07:26 AM   #3
Just call me Andrew
Rewards Points: 1,020
You need to give details and ask a specific question if you want people to be able to help and give you an answer.
Andrew
secutanudu is offline   Reply With Quote
Old 09-26-2010, 04:15 PM   #4
Nitwit's Avatar
If you connect the two panels together using a nipple to run your wires wouldn't that bond everything together in both panels?
Nitwit is offline   Reply With Quote
Old 09-26-2010, 07:27 PM   #5
" Euro " electrician
frenchelectrican's Avatar
Yeah but the gotcha is the second panel all it depending on how you conferation it some will treat as subpanel and some will treat as main panel but that part there is a fine line to crossover and to simplify it any other panels which is not a main supply panel treat them as subpanel.
Merci.
Marc
Old 09-27-2010, 06:00 AM   #6
A nipple or conduit will connect the panels, but the neutral buss of the subpanel is not affected, since it is not connected to the subpanel(floats).
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Panel ground questions Joe F Electrical 12 08-05-2008 09:48 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 10:17 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
