Is This A Ground Or An Easy Fix? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 06:24 AM   #16
Rewards Points: 1,548
Originally Posted by FrustratedMom View Post
... I tested the office outlet with a meter and got nothing at all (110v). Attempted to test the resistance (1K) and it spikes. Which, if I understand correctly, is supposed to happen with a switch but not on the outlet.
Now, here's another thing that baffles me. If I have the old switch attached and test for resistance with the switch in the off position, I get nothing on both outlet and switch. But if I turn on the switch, I get a big spike (1K) in the outlet on the wall. .
Breaker! breaker! (with a double meaning).
Go, break!
Important reminder. Turn off the power before doing resistance or continuity measurements. Otherwise you can damage your meter or cause an arc that startles you.
Also, for best results, at least one of the wires or terminals you touch the meter probes to when doing resistance readings should have nothing else connected to it when the meter probe is touched. (Unless the entire bundle and all pathways leading from the bundle are part of the test subject.)
Now back to our regularly scheduled programming.
If it worked before and you changed out a light or receptacle and now it does not work, you probably made a mistake in hooking it back up, or a wire broke somewhere. It is not unheard of for a wire to break inside the insulation. Not because the wires are old but rather the receptacle was changed out once or twice in the past and the wires can only take so much flexing and restuffing back into the box.
Old 08-09-2012, 06:42 AM   #17
Originally Posted by stickboy1375 View Post
The OP is named "Frustrated MOM"
Explains the frustrated part if the OP is a man.
saladdin is offline   Reply With Quote
Fake Ground at Panel Perry401 Electrical 28 05-25-2013 03:29 PM
Bosch 11245EVS Rotary Hammer Drill for Ground Rods tedallen Tools 0 06-02-2012 04:52 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
Ground question. mystery guest Electrical 5 07-24-2008 12:47 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
