Ground Conductor Size For Feeder - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 07:16 PM   #16
Electrician
SD515's Avatar
Rewards Points: 504
I didn’t catch the 100A earlier, nor did I do the math on the ‘oversizing’, but I’d bet on kbsparky’s side now that I see that.
I’ll keep my fingers crossed for ya Will !!
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
kbsparky (06-05-2011)
Old 06-05-2011, 07:46 PM   #17
I ask the impossible!
Rewards Points: 704
I'm mostly hoping to work out with the supervisor that he'll take pity on my unemployment and the inspectors bad people skills and waive reinspection tommorrow, then I'll be able to get one more reinspection if needed by doing it together with a final inspection on the older permit I have open.
Not ready yet for final because I have 3 outlets where drywall isn't up yet. That I can do tommorrow, although I would still have Tuesday because he has Tuesdays off I think.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Grounding VS Bonding BillyD Electrical 24 06-22-2008 12:14 PM
