Ground And Breaker Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 07:01 PM   #1
Ground and Breaker Box
Hello, recently I found that my phone NID ground wire was connected to nothing. It was connected to a metal pipe which was replaced by a plastic one. There was another unattached wire near the same pipe linked to the neutral of my breaker box.
It made me find that the ground bars of my breaker box are connected to nothing at all.
3 questions here.
1-What was the purpose of attaching the neutral and my other wire to the pipe?
2-What should I do now that the metal pipe's gone?
3-Why are the ground bars attached to nothing?
Here's some pictures of the breaker box.. it's a big mess. (The wire coming from the top is the one that was going on the pipe)
Olograph is offline   Reply With Quote
Old 09-10-2012, 07:10 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
I can only assume that the neutral is properly bonded to the panel box. Hard to tell from the pics. THIS is your safety ground.
Old 09-10-2012, 07:40 PM   #3
Rewards Points: 240
I think what he's saying, Petey, is that the box isn't bonded to anything.
It references the system ground to actual earth, so that the grounded parts of your electrical system (including metal cases of appliances) can't float to a large potential above ground. (Well, not under most circumstances... )
Install a grounding rod and connect your electrical and phone grounds to it. Search through here; there's a lot of threads on grounding rods.
They are actually bonded to the box itself. So is the bar where the service neutral and the grounding wire are connected. By that means, the ground path is conveyed from the circuit grounds to the system grounding wire.
fa_f3_20 is offline   Reply With Quote
The Following User Says Thank You to fa_f3_20 For This Useful Post:
Olograph (09-10-2012)
Old 09-10-2012, 07:42 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
This looks like a sub panel as all I see are 2 pole breakers. You should have a 4 wire feed from the main and that is where the ground is connected. Is this panel in the same building as the meter?
Coastal South Carolina
Old 09-10-2012, 07:54 PM   #5
System ground in this case being the neutral?
I see no grounding rod yet nor inside or outside. Is this possible that it's done outside my property like near the pole? (So the neutral would connect to the ground outside?)
I just don't want to alarm the homeowner for nothing.
So the ground bar is connected to the neutral bar via the breaker box case itself?
Thanks a lot by the way
Old 09-10-2012, 07:59 PM   #6
The meter is to the top left of this main box. The top-left wires are coming right from the meter.
This is the main panel, there's a second to the right with many switches. It's connected to the main by one of the switch..
I see only 6 breakers, which are which? Honestly what is a "pole" breaker, the black ones?
Old 09-10-2012, 08:00 PM   #7
HOLD UP!
Are you renting this place???
Old 09-10-2012, 08:04 PM   #8
I am renting this place but I got full authorization of the owner regarding electrical, phone and cable configuration. Like as long as I put it back together before I leave.. I could drop a wall if I'd want to..
It makes the owner happy, cause at last there's someone taking care of these things. If you would've seen the basement when I arrived. Tons of nails, screws erupting from the wall and ceiling to pierce your eyes + a mega load of cables from the thousand cable and phone installation before, most of them cut off.
Old 09-10-2012, 08:10 PM   #9
Regardless, I don't feel comfortable with this.
Good luck.
Old 09-10-2012, 08:13 PM   #10
Good luck.
I wonder why, cause it's a DIY forum, not a professional licensed forum, what is it that you don't want to encourage???!?? and at the same time I don't care. Seriously man, why bother saying this anyways? Ahahah
Old 09-10-2012, 08:24 PM   #11
Resi EC
Rewards Points: 252
In your first picture, at the top in front of the main breaker, is that a green screw? If it is that is bonding your grounds and neutrals together, through the case.
The wire exiting the panel out the top, did it go to your water pipe system?
Gac66610 is offline   Reply With Quote
Old 09-10-2012, 08:29 PM   #12
Yes it did
Old 09-10-2012, 08:37 PM   #13
Resi EC
Rewards Points: 252
Do you still have metal pipe at the water service entrance?
Old 09-10-2012, 08:38 PM   #14
Is that some kind of screw of codename or you wonder if the screw's actually green?. If you mean the screw to the right of the main breaker.. I assume it's the one of a different color.. it's definitely not silver like the others. Green, it's hard to say.
Old 09-10-2012, 08:41 PM   #15
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
What he doesn't want to encourage is someone other than the home owner doing electrical work.
In some areas, this is not allowed even if you have the owners permission.
Yes this is a diy forum, but directed at the home owner and not tenets.
The Following User Says Thank You to jbfan For This Useful Post:
Jim Port (09-12-2012)
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
