Ground Bar Neutral Bar Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2011, 03:31 PM   #1
Rewards Points: 280
Ground bar neutral bar question?
I saw something and did not realize it at the time because I am not an electrician.
The sub panel has the bare copper or ground wire going to one bar. The white or neutral wire going to another bar. That looks right.
The main panel has all the bare copper ground wire's going to one bar and all the neutrals/white wires going to the other bar. I've never seen that before.
I questioned it later and was told that is how the inspector wants it done. This is a residential installation, I do not know if the ground and neutral are bonded in either box.
Is this code now, that the wires must go to separate bars, in the main panel? The reason I ask I am getting a quote from the electrician that did this job and it does not seem right. JIm 0311
jjrbus is offline   Reply With Quote
Old 07-07-2011, 03:37 PM   #2
Master Electrician
Rewards Points: 3,870
The main panel has the neutrals and the grounds on the same bar or on bars that are electrically connected.
brric is offline   Reply With Quote
Old 07-07-2011, 04:05 PM   #3
Licensed electrician
Rewards Points: 1,612
Can you post a pic? Often times I install the add on ground bar even when not required.
Old 07-07-2011, 05:37 PM   #4
I=E/R
a7ecorsair's Avatar
Are you sure this "main panel" is a main? To understand this you will have to verify if there is some other disconnect between the meter and this panel or if the wires from the meter connect directly to this panel's main breaker.
a7ecorsair is offline   Reply With Quote
Old 07-07-2011, 06:31 PM   #5
Rewards Points: 280
I can not post a picture and probably will not have access to house again!
mixed neutral and ground Daneel Electrical 6 05-30-2011 06:38 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
Ground and Neutral in Panel bvbellomo Electrical 21 07-17-2010 09:53 AM
general service panel question about ground / neutral BlueBSH Electrical 3 03-17-2010 06:55 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
