Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2012, 07:18 PM   #1
Rewards Points: 80
Ground
Doing some bath remodel and noticed that there is a copper braided wire attached to the galvanized pipe in the attic.
Going to be removing the galvanize and replace with cpvc.
Outside by the box is a grounding wire to the ground.
Can I safely delete the one on the galvanized pipe?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 09-17-2012, 07:25 PM   #2
Rewards Points: 1,192
See where it was used for. Might be for a grounding point for a circuit,which was permitted at one time.
bobelectric is offline   Reply With Quote
Old 09-17-2012, 07:51 PM   #3
Rewards Points: 80
Very possible because the house was recently re wired so it could be the old ground.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
