Grinder Pump Install For Basement Bathroom Elect Q.. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2013, 10:20 AM   #1
Rewards Points: 85
Hi all: Planning a basement bathroom install and I've been reading up on grinder waste pumps for pumping up the sewage waste to the main stack. They all seem to be 115vac plug in. Not hard wired. So my questions are first, how do I run the cord from the pump to an outlet? I want this to be concealed and not some ugly cord up the wall... Second, would it be better to plug it into a GFCI recept. or a same breaker? Third, does the pump need a dedicated circuit or can it share the 20A circuit for the bathroom? Fourth q is would it be overkill to install a 20A GFCI breaker on the circuit for the bathroom and GFCI outlets throughout?
Thanks!!!
JohnC20 is offline   Reply With Quote
Old 10-30-2013, 10:34 AM   #2
Rewards Points: 12,902
You run a new dedicated non GFI 20 amp. line to the pump.
A bathroom can not share outlets with any other room.
Old 10-30-2013, 02:29 PM   #3
Rewards Points: 85
Originally Posted by joecaption
You run a new dedicated non GFI 20 amp. line to the pump. A bathroom can not share outlets with any other room.
thanks. I guess I'm protected by the pump three prong plug?
Old 10-30-2013, 02:42 PM   #4
joed's Avatar
Rewards Points: 11,632
The grinder pump might not be in the bathroom. I don't think it needs a dedicated receptacle but I think I would probably put it on one.
The cord could follow the pipe to the receptacle. The cord should not be hidden inside a wall.
Old 10-30-2013, 03:06 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 358
Most, if not all sewage basins come with gas tight lids. Within this lid is a gas tight grommet to feed the pump and/or float cords through.
Also consider an alarm float as well
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Know A Little (10-30-2013), Philly Master (10-31-2013)
Old 10-30-2013, 03:43 PM   #6
GBrackins's Avatar
Rewards Points: 2,108
my following question has nothing to do with the original question. Are you on a sewer system or a septic system (tank, leach field, etc.) I ask because a girder pump will cause damage to a septic system as solids would be ground up and enter the leach field where the aerobic bacteria will not digest the ground up solids.
if on a septic system you would need a effluent pump that is capable of pumping solids.
Just thought I should ask ....
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
Old 10-31-2013, 08:17 AM   #7
Rewards Points: 85
Originally Posted by GBrackins
my following question has nothing to do with the original question. Are you on a sewer system or a septic system (tank, leach field, etc.) I ask because a girder pump will cause damage to a septic system as solids would be ground up and enter the leach field where the aerobic bacteria will not digest the ground up solids. if on a septic system you would need a effluent pump that is capable of pumping solids. Just thought I should ask .... Good luck!
Hi- no.. City sewer. But thanks for asking.
DIY ductless AC/heat pump install gbook2 HVAC 5 08-18-2013 08:27 PM
Bad Sump Pump Install Out2pasteur Plumbing 5 07-15-2013 06:41 PM
New well pump install; pump won't start chi_town60608 Electrical 14 05-24-2013 07:00 PM
Grinder pump venting big daddy-o Plumbing 7 03-02-2008 09:54 PM
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 05:08 PM
