Grid Tie Solar Panel Manual Transfer Switch Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 06:05 PM   #1
I have a Grid Tied Solar Panel on my house. I am thinking that in an event of a power outage or disaster, my solar panels are pretty much useless if there is no grid power coming into the house. Would it be possible to hook up a manual transfer switch to the inverter so that it would cut the grid connection and run the power for the times the house has sunlight? I know the grid tie inverter requires a voltage detection to run due to safety, but I was also thinking if I could tie that in to a portable generator to power the inverter.
Is something like this possible and if so how can I achieve it?
tomguy is offline   Reply With Quote
Old 06-16-2010, 08:34 PM   #2
The system I saw was pretty complex due to failsafes and various time delays.
Is it
IF no PoCo
THEN
disconnect PoCo
AND
run house on solar.
Also,
IF
no solar
AND
no PoCo
THEN
run house on generator
Old 06-16-2010, 10:46 PM   #3
Electrical Supplier
Rewards Points: 150
Im with YoY....These systems are very complex and such....There are quite a few ways to destroy sensitive equipment here man.....Better spend the cash and get it done right.
LyonsElecSupply is offline   Reply With Quote
Old 06-19-2010, 12:49 AM   #4
First of all, does a system exist? I'm just looking for something that will automatically disconnect the PoCo and then run off the solar power. I don't care about having power at night, but at least when the solar is functional I would like to get some electricity into the house.
Any ideas? I don't need to have a battery backup since I wouldn't care about having it run at night.
THanks
Old 06-19-2010, 12:38 PM   #5
That should be easy.
When the panels produce enough voltage from the inverter the setup drives a large relay that switches the house from the PoCo to solar.
For temporary cloudiness, though, without a battery, the unit might then switch back to PoCo. This kind of cycling is probably undesirable.
Old 04-08-2011, 04:55 PM   #6
tomguy,
I was wondering if you were able to make any progress on this front. I have a grid tied system and yes, if the grid were to die, my panels would be useless. I'm looking for a way to power my solar panel inverters in the event of a power failure. I thought there may be an option for powering the inverters with a small generator.
goacom is offline   Reply With Quote
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 09:36 AM
Standby Generator & Transfer Switch JRoot Electrical 9 06-12-2011 10:14 AM
1 phase generator feeding a 2 phase transfer switch MAP40 Electrical 12 01-01-2009 08:38 AM
Solar panel for koi pond pump? Badfish740 Electrical 5 02-29-2008 05:29 AM
Furnace Transfer Switch... caseywa HVAC 16 02-18-2008 10:14 AM
