Grid Tie In For Solar Electric Home. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 10:32 AM   #1
Grid Tie in For Solar electric home.
I need best information or guides to put in a complete Solar Electric system for my home. Need to know best places to buy equipment and solar pannels ect..
Ken Rosser is offline   Reply With Quote
Old 01-10-2011, 04:38 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
Just a heads up this is not a DIY project. Very complex. Sorry I don't have info on the best place to get it or preferred sellers, but I'm sure some one will chime in.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-10-2011, 08:44 PM   #3
Electrical Supplier
Rewards Points: 150
Do not do this without extensive knowledge of PV systems.
I suggest a licensed electrician for installations that involve grid tie ins.
Most POCOs require a permit to be pulled.
My FIRST step if I were you (i have researched this on my own also) is to contact the POCO and they should have a department or contact that handles Renewable energy tie ins.
If not contact your State department of energy, utilities regulating authority or commerce.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-11-2011, 12:19 AM   #4
" Euro " electrician
frenchelectrican's Avatar
I will suggest this is not a simple DIY task on this one I have deal with couple diffrent verison and you have to get the POCO invold on this one due they have some very strict requirement to meet plus NEC code will cover this very well. And will need a disconnect switch { the location will depending on the local code }
A Electrician will able do this without too much diffucitally if they are famiuair with the NEC code { it will be found in few diffrent art sections }
Of course the Permit will be required no question asked.
You can able goggle couple manufacters for solar panels but make sure they do meet the UL and NEC code requirement.
Merci,
Marc
Old 01-11-2011, 07:07 AM   #5
Rewards Points: 1,538
Solar systems require a special module to mix utility and home generated power. Very rarely does the solar power system provide all of the home's needs so a transfer switch is not used unless you also have a generator. Any dealer selling complete systems has this module.
Some versions of the module feed excess solar power back into the power lines. You need to find out from the utility whether they reimburse you for the power.
AllanJ is online now   Reply With Quote
Point of use vs Whole Home Tankless Electric joergeske Plumbing 1 09-30-2010 03:52 PM
Grid power loss indicator ? Roy Rowlett Electrical 1 03-20-2010 09:53 PM
magnetic electric generator for home leahpar Electrical 8 09-14-2009 08:52 PM
Cost to subcontract modest home catbird Building & Construction 25 05-25-2009 07:38 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
