Greenie Wire Connectors - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 04:16 PM   #1
Greenie wire connectors
Sorry if this sounds lame but I've never used the "Greenie" wire connectors to splice my grounding conductors. If I have 2 NM cables in a metal box and a receptacle how do you splice so there is a pigtail for the receptacle.
Thanks,
Ed
whatrymes is offline   Reply With Quote
Old 03-23-2011, 04:40 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Cut one ground wire shorter, twist and put the long wire through the hole in the wire nut.
Attach to device.
Old 03-23-2011, 05:08 PM   #3
Attach to device.
I assume pre-twisting is out?
Old 03-23-2011, 05:21 PM   #4
Rewards Points: 81
No you still pre twist. It is easier with two but you can do it with mutiple. It may take you a few times to get it right.
Chevyman30571 is offline   Reply With Quote
Old 03-23-2011, 05:26 PM   #5
Rewards Points: 1,512
Pigtails should come out the large end of a greenie, except if you need two pigtails and none of the incoming ground wires are long enough to double as pigtails, you can cut one double length (10-12 inches), stick it halfway through the greenie, screw it onto the other ground wires, and then use the two ends as pigtails.
Twisting the ground wires can still be done.
What type wire to use from transfer switch to outdoor outlet brjl Electrical 32 11-20-2013 08:36 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Push in connectors vs. wire nuts sanny651 Electrical 5 02-17-2010 08:26 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
