Old 11-08-2010, 11:44 AM   #1
esk
Greenhouse thermostat
Would appreciate any advice where I might buy following type of thermostat. Tolerant of atmosphere in a greenhouse, although would be protectively housed so rugged, domestic variety acceptable; preferably low-voltage (either battery or transformer); digital display covering ambient temperature and setting points; battery back-up of set programmes; two low-voltage outputs to secondary relays, minimum setting to control heating, maximum setting to control cooling fan. Optional hysteresis would be ideal, however, adding this probably suggests I still believe in Santa Claus.
Velleman offer a DIY kit with similar specifications, but in my experience this is alarmingly unstable in operation and if the mains blinks loses all its settings, cheerfully displaying the message, 'FAIL'. At 0300hr on a winter's morning this is unhelpful.
Best wishes.
esk is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
