Old 02-16-2010, 06:09 PM   #1
Question
Greenhouse
I'm looking at getting a 15 amp cicuit out to a greenhouse for light duty needs, no heaters, big fans, etc.
The poly covered structure is approx. 75ft away from the house and I was wondering if I need to install a sub-panel and what size wire I would need to use for this run distance.
I'm assuming wire would have to be buried in conduit and GFI protected?
Thank You
Lager is offline   Reply With Quote
Old 02-16-2010, 06:22 PM   #2
Xtreme DIY'r
Greenhouse
Where are you located ?
Old 02-16-2010, 06:25 PM   #3
Greenhouse
Hey Dave,
I'm in Ontario, Canada.
Old 02-16-2010, 06:40 PM   #4
Xtreme DIY'r
Greenhouse
I'm not sure on codes up there
Here you can use direct burial wire at 12" if GFCI protected before it goes into the ground
Otherwise I think its 18"
Conduit protects the wire better & allows you to run new wire if there is a problem
I'd run #12 wire & use a 20a breaker
Costs are about the same & that way you have the power if needed
And voltage drop will be less on lower loads
Old 02-16-2010, 06:52 PM   #5
Greenhouse
Thanks Dave, I do appreciate it!
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 08:37 AM
greenhouse glass roof seal? wt timberworks Roofing 4 02-14-2010 12:16 PM
Another Greenhouse Construction Question Flavio Building & Construction 9 11-23-2008 12:08 AM
Slab foundation for 16 x 20 greenhouse prices? sailorfred Flooring 2 06-06-2006 08:25 AM
