"Greenfield" Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 02:16 AM   #1
"Greenfield" conduit
Does the NEC allow "Greenfield" conduit to be used in commercial applications?
Thanks.
Goboomers
goboomers is offline   Reply With Quote
Old 11-15-2008, 02:46 AM   #2
DIYer
If you mean flexible metal conduit, then yes, that's what it's made for.
It should go without saying, but a DIYer doing commercial wiring is, however, forbidden.
Gigs is offline   Reply With Quote
Old 11-15-2008, 07:48 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and there are a couple rules to using greenfield that are different than other metal conduits (emt, rmc)
conduit fill can also be different as well (your other thread) but 4 #8's will fit in 3/4 greenfield as well. Just curious, how do you end up with 4 #8's.
Old 11-15-2008, 08:45 AM   #4
Gigs and Nap . . thanks.
Nap, It's for a Kitchen (home type) stove (oven with burners on top). I'm planning 40 amps, two hot wires, one neutral, one ground, all #8. No?
Old 11-15-2008, 09:07 AM   #5
nap
You talking to me?
nap's Avatar
Aha! caught you. You are definately not an electrician. We are too cheap to use oversized ground conductors. You only need a #10 ground. (NEC table 250.122)
You can use a #8 if you want though, just not required.
Old 11-15-2008, 09:57 AM   #6
Thanks, I appreciate the help. Great website!
Goboomers
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
Conduit issues - help needed nymackem Electrical 19 11-05-2007 06:45 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 08:35 PM
