Green Wire Caps With Hole In It - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 10:50 PM   #1
Green wire caps with hole in it
Regarding the green cap with a hole in it, can I use this when pigtailing grounds leaving one of them long so that it can connect to the terminal instead of using an additional wire in the pigtail?
Drliebs is offline   Reply With Quote
Old 08-10-2011, 11:19 PM   #2
Rewards Points: 79
I don't see why not (although I've never seen such caps). As long as the connection is tight (pull on each wire after it is installed).
CheapCharlie is offline   Reply With Quote
Old 08-10-2011, 11:40 PM   #3
Thadius856's Avatar
Rewards Points: 504
I believe that's their intended purpose. I have a bag of them laying around, though I admit that I've never gotten around to using them. I found them somewhat inconvenient that the entire length of the wire had to be bare 14g, when I was pulling runs of green THHN.
Thadius856 is offline   Reply With Quote
Old 08-11-2011, 01:23 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
AFAIK, that's the only thing you can do with them. That's what they're for.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
electures (08-11-2011), SD515 (08-11-2011)
Old 08-11-2011, 04:07 AM   #5
Thadius856's Avatar
Rewards Points: 504
I'm in the process of retrofitting grounds to all outlets (and later switches) in my home. They all collect in a single junction box, and I had considered using these.
I decided to just use a bunch of regular wire nuts instead.
Old 08-11-2011, 04:08 AM   #6
Thadius856's Avatar
Rewards Points: 504
Common Ground on Multiple Circuits
Is there any reason why grounds originating on different circuits should not be connected? They all go back to the same bar, so I don't see any reason why not, but wanted to be sure.
Old 08-11-2011, 05:28 AM   #7
Sparky
Rewards Points: 510
all grounds should always be put together. neutrals are to be kept separate
Techy is offline   Reply With Quote
Old 08-11-2011, 07:07 AM   #8
Rewards Points: 1,512
They can also be used with nothing sticking out the small end.
A few other tricks:
If you need two ground pigtails you can cut one 12 inch piece of bare wire instead of two 6 inch pieces and you insert the 12 inch pigtail halfway through the green wire nut and then screw it onto the remaining wires.
If you have too many ground wires to go into one wire nut and one ground wire is long enough, put the latter through the large end and out the hole (at least 2 inches showing) and screw some of the wires under that wire nut. Add a second green wire nut on the end sticking through the first wire nut to connect more ground wires, etc.
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 06:22 PM
green wire kupalino Electrical 4 12-19-2009 01:12 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
sealing a masonry hole for a wire mcvane Electrical 2 06-18-2008 09:18 PM
