-   -   GREEN subpanel wiring 120V (http://www.diychatroom.com/f18/green-subpanel-wiring-120v-116824/)
Rayhay72 09-10-2011 10:01 AM
OK, Ive installed a combo, wind turbine/solar power system, and it's time to Go live. Few problems, I'm not really understanding how to wire my QO sub panel. This has a mechanical interlock in it, so I can switch from GREEN power(from my inverter) to Grid power. Now inside this Sub panel, there are 3 bus bars 2 H and 1 N. I have 6# wires run from main Panel (off a single pole of a 60 amp double pole breaker) to an external disconnect (required by utility) which then comes inside to another 60Amp breaker (inside disconnect) BTW ALL THIS IS ONLY 120 V and all the diagrams i see are 240V. from this 60 amp I have the hot and neutral jumped to the QO sub panel ( its a Square D by Schneider, 4 Spot 60Amp) the other side the breaker is the AC in to my inverter. NOW how the heck do I wire my sub Panel???? I have Hots from both my inverter and from MAIN, but I want inverter output to power sub with the ability to switch to Grid power... I'm so confused
Code05 09-10-2011 10:18 AM
You have a 240v supply from main panel and a 120v supply from inverter to sub-panel? That isn't going to work.
Rayhay72 09-10-2011 10:22 AM
nope, only 120v
No sir, the 60 amp double pole breaker is only used on ONE leg from main panel, thus making it 120V. :eek:
