Grabbing Power From A Light Switch Box - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 09:44 PM   #1
Grabbing power from a light switch box
I have been reading some of the old posts. Some posts seem to mention that you can use a light switch box to grab power and run another cable to another device. Is this right?
Let me describe what I am imagining.
I am running NM cable from my breaker box to a light switch junction box.
Instead of connecting the lead only to the light switch and its light, I can splice another cable onto the lead. That other cable can then go to another device (like another light switch on another wall).
If this is possible, how would all the wires (the lead wire, the cable going to another device, the wires for the light switch in the first box, and the wires going to the first light) all be spliced together?
Thanks for your time,
Red
RedBear is offline   Reply With Quote
Old 01-11-2010, 09:55 PM   #2
300zx's Avatar
Post
Yes it's possible,Lets say you have 3 wires in your switch box.Wire nut your whites together,then wirenut your grounds and leave a pigtail to ground switch,That leaves 3 blacks the one going to the light put on switch the other two wirenut together with a pigtail and put pigtail on the last screw on switch.
300zx is offline   Reply With Quote
Old 01-13-2010, 01:20 PM   #3
I see
Thanks, 300zx. I get it!
Old 01-13-2010, 01:28 PM   #4
300zx's Avatar
No problem,If you have any other questions someone here will take you in the right direction.
power to light switch 44070dart Electrical 17 11-27-2009 08:31 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 02:33 AM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
GFCI light switch trips once per night ???? mw6263 Electrical 11 07-25-2008 11:05 AM
