Gounding Requirements In Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2008, 08:08 AM   #1
gounding requirements in shed
I had a shed close to the house that was wired to the main house. I relocated the shed about 300 feet from the house. I left all the electrical wiring inside the shed intact and just clipped the wire where it entered the shed.
I came across a solar kit at Amazon and decided to try it out for powering the shed. Where I had clipped the wire, I attached a male plug and just plugged it into the inverter from the solar kit. Everything is working just fine but I am concerned that there is nothing running to ground on the whole system.
The charge controller has a grounding screw on it and I was thinking that would be the logical point to ground the system. Any help on what I should do to ground the system would be appreciated.
Brian
bmcmahon is offline   Reply With Quote
Old 06-17-2008, 08:36 AM   #2
Master Of Nothing
mr500's Avatar
How many wires did u CLIP when you moved the shed? should have been 4. 2 hots, 1 neutral and 1 equipment ground. How big is the breaker feeding this shed?
Since it is detached, it should have a gnd rod buried 8 ft. Then attached to that is a clamp rated for direct burial. You then run a gnd wire from the gnd buss, out to this clamp/rod. Also your ground and neutral must be separated. they cant be on the same buss in the shed. Hope this helps for starters.
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 06-17-2008, 09:24 AM   #3
The cable I clipped had only 3 wires. Two were coated (a black and a white) and the other was uncoated.
I connected these to a heavy duty 3 prong plug just as if it were the cord on a light. I plugged this into the inverter from the solar kit and bingo -- the lights in the shed worked. The outlets in the shed worked. The outside lights on the shed worked.
For the most part, the inverter is off. I turn it on as needed. The charge controller also allows me to run low voltage lights at night which come on automatically at dusk.
I was thinking I'd drive a ground rod in and connect a ground wire from the rod to the grounding screw in the charge controller. I don't know what you mean by ground buss (there is no electrical panel in the shed). Nor do I know what you mean by "your ground and neutral must be separated." Could you clarify? Thanks.
Brian
running uf to shed bobo60 Electrical 12 04-20-2008 01:41 PM
expanding existing concrete pad for shed lz300 Building & Construction 1 04-06-2008 08:20 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
