04-22-2008, 09:25 PM
#16
Moderator
Got an Estimate
You won't like me for this, but I inspect panels every day wired by licensed (often master) electricians. I often see neutrals doubled or tripled up under the same lug. It is wrong every time, no matter who does it.
Depending on the panel, you can typically double or triple grounds of the same wire size under the same lug. Perhaps you can consolidate some of your grounds under the same lug, thereby creating room for your neutrals that are doubled up.
Or, you could add a ground bar (or a larger ground bar) to the panel jacket and use the current bars for neutrals. They don't have to be isolated as long as this is your main panel (where the main disconnect is) and not a sub-panel, but you can't land neutrals and grounds under the same lug.
04-22-2008, 09:59 PM
#17
Master Of Nothing
Got an Estimate
Originally Posted by Nhrafan
After having read through this post I have to ask a question on an install I just did.
I just installed a new service panel and a generator transfer panel.
The generator panel came pre-assembled with 9 breakers installed in it.
The brochure states it can hold up to 16 circuits.
The panel itself has a ground bar and a separate neutral bar.
Problem I have is that the ground bar has 5 holes in and the neutral has 6 holes in it.
Why would they do this if you are not supposed (or aren't allowed) to double up any of them?
What to do about a situation like this?
The panel is a Powerstay Cat. No. 501210
http://www.gen-tran.com/assets/pdfs/...chureFINAL.pdf
http://www.gen-tran.com/assets/pdfs/MTSinstall.pdf
Just a hunch here, but maybe they want you to go back out to the store and buy more buses to "upgrade/expand" the panel. They give you so many but you have to BUY another buss to take advantage of the panels' full potential. Just guess. Lot of companies do this. It says it is EXPANDABLE but not until you purchase more stuff.....
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
04-23-2008, 11:13 AM
#18
Got an Estimate
If I have an unused 220 in my basement. The wired have been pulled and capped from the breaker, but the neutral is still connected. Since it is not connected to a breaker, can I remove the neutral to gain space for another circuit on my neutral bar?
04-23-2008, 11:37 AM
#19
Electrical Contractor
Got an Estimate
Yes you can.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
04-23-2008, 11:43 AM
#20
Got an Estimate
for your job... the hardworking/time consuming part is running the wire and drilling holes.... if that was done... the rest is the fast part.... but more scarely part if one will say as you need to work on the main panel... I think if you can do all those running wire stuff yourself... you might as well do the other two parts as well after reading a good book from the library... make sure your state allow home owner to do that though... but normally electrical work requires inspection and that also cost money...
04-23-2008, 11:59 AM
#21
Got an Estimate
Thanks everyone, I will give it a go and ask any questions if I run into something. I'll probably shut the main off for peace of mind. Thanks again!
04-23-2008, 09:21 PM
#22
Sparrky
Got an Estimate
I am an Electrician of some 15 years + . . .you seem like a nice fella
After reading ALL of the posts above . .my opinion is that this is NOT an DIY'er project..it has the potential of " electrocute the home owner / start a fire / blow up the new microwave" project
Please get a few more bids if needed then have a professional do it,
no one in here will lose any sleep if your DIY attempt ends badly . . .but you will and it isnt worth it
This isnt DIY . . .home run..panel full....nope pass on this one Friend
04-26-2008, 12:39 PM
#23
Got an Estimate
No, One wire per terminal. Go to HD or lowes and buy a neutral terminal bar kit. If you know the brand and model number you can get one that will fit the mounting hole arrangement. Most panels will accept more than one terminal bar. Take a good look at the one you have. Is there a mounting hole below or above the existing bar? If so, you may have a short bar and it can be replaced with a longer one with more terminals.
Do not try to attach a terminal bar with sheet metal screws or where one is not intended to be installed.
Find a longer terminal bar or install another one if the panel will accept it.
The electricians that put more than one wire under one terminal were either lazy or did not know it is a code violation.
Ps.....You may have to go to an electrical supply house if the big box stores do not carry your type of panel.
Kingsmurf.......You may be correct on this. The poster does not seem to have a clue regarding this work. No offense to the poster.
04-26-2008, 06:02 PM
#24
Got an Estimate
Ye of little faith. Its finished and works great! Thanks to everyone
04-26-2008, 07:43 PM
#25
Licensed Electrician
Got an Estimate
Depending on when it was done.
04-26-2008, 10:45 PM
#26
Power Gen/RS Engineer
Got an Estimate
JR-
From what you wrote, it sounds like it was acceptable at one time and then deemed illegal by a later code revision. Do you know/remember which year it was?
Thanks,
Jimmy
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
04-27-2008, 10:46 PM
#27
Got an Estimate
Originally Posted by BigJimmy
JR-
Thanks,
Jimmy
Jimmy, it was the 2002 code which prohibited it. Before that, this was in the UL listings, but many neglected to read those. In residential, it was common and accepted to put the neutral and ground for a given circuit under the same screw. At least in my neck of the woods. I'd like to see every panel come with enough terminals for all the grounds and neutrals to have their own hole. But then everyone needs a dream.
04-28-2008, 07:27 AM
#28
Got an Estimate
My home panel has more than one netural on a screw. I have run into this many times.
04-28-2008, 10:18 AM
#29
Got an Estimate
Originally Posted by jbfan
My home panel has more than one neutral on a screw. I have run into this many times.
Oh yeah, these are all over the place. Not correct, but very common. I see this a lot.
Now I worry a little that some DIY person is going to run to his panel and try to correct this, and neglect to turn off all the effected circuits before pulling the neutrals out, and frying some of his equipment. In that case, leaving them alone would be a better choice.
04-28-2008, 10:46 AM
#30
Got an Estimate
Good point, JR. I think it's important to remember that while having more than one neutral wire terminated under a screw is not legal by today's code standards, this condition, if it exists, does not compromise the integrity of an existing installation. Another reason to shut off the power before working on your electrical system if you are unfamiliar with what you're doing and/or dealing with.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
