I talked with a electrician on the phone this morning and he said to run a dedicated 20 amp circuit for my OTR Microwave he quoted me between $300-400. I can have all holes cut and drywall removed before installation. I told him I could even have the wires fished for him too and then he would just have to add a receptacle and possibly replace a breaker with a tandem. Does this estimate seem high considering I am doing most of labor myself?
Doing work for a contrator does not save you any money. Actually they do not want you to touch anything. Contractors and good electricians have their own way of doing things and your help is not wanted or encouraged. If you can do all this work yourself, why not do the whole job. Installing a circuit for a microwave is not difficult. In fact you can get all the answers you need to DIY right here.
Get 2 more quotes before you decide what to do. And do not offer to drill holes or anything else.
Not really all that high. He has to make enough money to justify the trip (and taking your job over another one), so you're probably going to pay a minimum trip charge no matter how little work he actually has to do.
He has business expenses as an electrician. Materials, insurance, licenses, permits, labor, etc...... There has to be an incentive for him to do your job, and if he's only making a couple connections the time involved would be less that $15. Most electricians I know wouldn't even look at a job for less than $300.
I have had work done with the same company and they only charge 60-70 per hour depending on who does the work. I figure if access is easy they shouldn't be there more than an hour. $70 plus materials, right? I just can't imagine $250 for materials for 30 ft of romex, tandem breaker and a receptacle. I was thinking more like 150-200.
I guess the only reason I am worried about doing it myself is that I don't have room on my panel for another circuit, so it would involve disconnecting breakers, adding tandems, and running cable. I've never done any of this before and I would hate to screw something up. Believe me, I would LOVE to save myself $300. I just want to be able to sleep at night.
I agree with JV. The electrician would rather that you didn't do anything. If he quoted it based on that, he may be concerned that he'd find something that was done incorrectly and then be faced with re-work that could kill his margin. Rememeber, he is responsible for the safety of the final product.
In further agreement with JV, if you went to all that trouble, you are very close to being done. Removing the existing breaker is really quite easy and installing a replacement is straightforward as well. If you are really leery about working in the panel, you could always turn it off via the main breaker or disconnect. If done via main breaker, the only parts that remain hot are the lugs at top (or bottom). Once the panel was dead, the amount of time that it should take to complete the work inside should be minimal.
This forum is frequented by many very competent electricians who would be more than happy to walk you through, no matter how many questions you have. JV is but one of these fine resources.
Sounds about right for what an electrician needs to make to travel out to a job. As stated, with overhead, insurance, etc, you aren't going to find a licensed electrician to do the job for cheap, unless you are related or good friends.... IMHO: The only way such a job would be less, would be if the electrician was already there doing other work....
Start by turning off the branch circuit breaker (killing the entire panel is up to you at this point. It is not necessary but as I mentioned, you may feel more comfortable). Many residential breakers are plug-in type. They typically have a catch on one side (usu. the side where the wire is connected). You engage the catch on a steel tab and rock it down until it meets the underlying bus. Apply pressure and the breaker will completely seat as it engages the bus. To remove, simply rock it back in the opposite direction (i.e. upward toward you as you look at it).
Once removed, take your screwdriver, loosen the terminal on the old breaker and remove the existing wire. Insert this into your new tandem and tighten the terminal down. Assuming that your new cable is already in the panel and you've connected the white neutral wire to the neutral bus and the bare green wire to the ground bus, insert the new hot wire (probably black) into the other terminal on the tandem and tighten down. Now you can install the tandem as described above and re-energize the existing circuit.
I often install the breaker first and then connect the wire to the breaker once installed however I've done this many times and am quite comfortable working in a panel. I recommend that you terminate the wires on the breaker while it is outside of the panel for ease and safety.
I will be using romex. Okay, so 12-2.
What about connecting to the neutral bar. I don't have room left. In fact there are couple of wires that are doubled up. Is this an issue? What can I do?
Also, should the 20 A that I replace with the tandem be one of the current 20A that supplies the kitchen, or can it be any 20A on the panel?
Unfortunately, yes, there is. According to the NEC,
408.41 Grounded Conductor Terminations.
Each grounded conductor shall terminate within the panelboard in an individual terminal that is not also used for another conductor. A neutral is considered a "grounded conductor."
The problem with putting multiple neutrals under a single terminal is that if you loosen the screw to remove one, you run the risk of inadvertently removing the other. If the neutral in question is part of a multi-wire branch circuit, the effect can be devastating. Even if it is not, if you accidentally removed the neutral on a circuit that is hot, that wire is now at line voltage and is capable of giving you a rather nice shock.
I've never had this problem so I'm not too sure of what the solution is. Don't worry though. Someone else will chime in.
Electrically, it does not matter. On the other hand, you may want to group the two kitchen circuits together due to the location that they both serve.
I know that the last time I had the pros in, this was apparently not an issue since there are at least 2 neutrals connected at one location. Anyone with any DIY solutions, or is a really a huge deal if more than 1 neutral is connected with another?
Do you have a make/model number for the panel? You can often find this on the panel somewhere or inside the door on the directory. Also if possible, open the panel and note if there are separate ground and neutral busses. Also note the number of neutral busses.
In my previous post, I mentioned the pitfalls associated with doubling up the neutrals and they are not trivial. That being said, could you do it? Well, electrically it would be fine but it would be an accident waiting to happen.
After having read through this post I have to ask a question on an install I just did.
I just installed a new service panel and a generator transfer panel.
The generator panel came pre-assembled with 9 breakers installed in it.
The brochure states it can hold up to 16 circuits.
The panel itself has a ground bar and a separate neutral bar.
Problem I have is that the ground bar has 5 holes in and the neutral has 6 holes in it.
Why would they do this if you are not supposed (or aren't allowed) to double up any of them?
What to do about a situation like this?
Just a hunch here, but maybe they want you to go back out to the store and buy more buses to "upgrade/expand" the panel. They give you so many but you have to BUY another buss to take advantage of the panels' full potential. Just guess. Lot of companies do this. It says it is EXPANDABLE but not until you purchase more stuff.....
Okay so I came home and looked at my panel. I noticed that I had 3 neutrals that were doubled up. 2 of them were done by the last guys I had come in. (the were liscensed). Would this mean that my panel can double certain neutrals? If not, what are my other options besides spending 400 to have a pro do the same thing?
You won't like me for this, but I inspect panels every day wired by licensed (often master) electricians. I often see neutrals doubled or tripled up under the same lug. It is wrong every time, no matter who does it.
Depending on the panel, you can typically double or triple grounds of the same wire size under the same lug. Perhaps you can consolidate some of your grounds under the same lug, thereby creating room for your neutrals that are doubled up.
Or, you could add a ground bar (or a larger ground bar) to the panel jacket and use the current bars for neutrals. They don't have to be isolated as long as this is your main panel (where the main disconnect is) and not a sub-panel, but you can't land neutrals and grounds under the same lug.
If I have an unused 220 in my basement. The wired have been pulled and capped from the breaker, but the neutral is still connected. Since it is not connected to a breaker, can I remove the neutral to gain space for another circuit on my neutral bar?
for your job... the hardworking/time consuming part is running the wire and drilling holes.... if that was done... the rest is the fast part.... but more scarely part if one will say as you need to work on the main panel... I think if you can do all those running wire stuff yourself... you might as well do the other two parts as well after reading a good book from the library... make sure your state allow home owner to do that though... but normally electrical work requires inspection and that also cost money...
I am an Electrician of some 15 years + . . .you seem like a nice fella
After reading ALL of the posts above . .my opinion is that this is NOT an DIY'er project..it has the potential of " electrocute the home owner / start a fire / blow up the new microwave" project
Please get a few more bids if needed then have a professional do it,
no one in here will lose any sleep if your DIY attempt ends badly . . .but you will and it isnt worth it
This isnt DIY . . .home run..panel full....nope pass on this one Friend
No, One wire per terminal. Go to HD or lowes and buy a neutral terminal bar kit. If you know the brand and model number you can get one that will fit the mounting hole arrangement. Most panels will accept more than one terminal bar. Take a good look at the one you have. Is there a mounting hole below or above the existing bar? If so, you may have a short bar and it can be replaced with a longer one with more terminals.
Do not try to attach a terminal bar with sheet metal screws or where one is not intended to be installed.
Find a longer terminal bar or install another one if the panel will accept it.
The electricians that put more than one wire under one terminal were either lazy or did not know it is a code violation.
Ps.....You may have to go to an electrical supply house if the big box stores do not carry your type of panel.
Kingsmurf.......You may be correct on this. The poster does not seem to have a clue regarding this work. No offense to the poster.
Oh yeah, these are all over the place. Not correct, but very common. I see this a lot.
Now I worry a little that some DIY person is going to run to his panel and try to correct this, and neglect to turn off all the effected circuits before pulling the neutrals out, and frying some of his equipment. In that case, leaving them alone would be a better choice.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
