Got A Easy One For Y'all - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2013, 10:42 AM   #1
Got a easy one for y'all
I have a porch light and a flood light pretty close together but on different switches . I would like to get the flood light on the same switch as the porch light . Can I just cut the wires in the attic and wire nut them together or any suggestions ? Thanks
Kpack is offline   Reply With Quote
Old 11-10-2013, 10:44 AM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
jumper wire from porch light "BOX" to the motion sensor "BOX" ....LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
Kpack (11-10-2013)
Old 11-10-2013, 10:44 AM   #3
Rewards Points: 236
i don't see why not. make sure you use a junction box.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Kpack (11-10-2013)
Old 11-10-2013, 10:45 AM   #4
Licensed electrician
Rewards Points: 1,788
Are the switches next to each other? It would be easier to make changes at the switches if so.
The Following 4 Users Say Thank You to Jim Port For This Useful Post:
brric (11-10-2013), Kpack (11-10-2013), k_buz (11-10-2013), stickboy1375 (11-10-2013)
Old 11-10-2013, 10:45 AM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If the switches are in the same box, then all you have to to is pigtail the switch legs to a single switch.
The Following User Says Thank You to k_buz For This Useful Post:
Kpack (11-10-2013)
Old 11-10-2013, 10:53 AM   #6
Rewards Points: 516
LMAO ....good call !!!! like DUH ....
Kpack (11-10-2013)
Old 11-10-2013, 12:16 PM   #7
The switches are not close to each other. That's the problem the switch for flood light is down by the back door we don't use. The porch light switch is by the door we use. I'll get some junction boxes and mark them . Thanks.
Old 11-10-2013, 12:41 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Who wired it like that?
Old 11-10-2013, 04:05 PM   #9
It was wired that way when the house was built about 20 yrs ago by an elec contractor . There's a lot of switches by the door we use and the door to the left that's hard to see is in the wash room has the flood lights each end of the house and some other switches by it. If I had it to do over again I would have them wire it different but that's what I have.
Old 11-10-2013, 04:06 PM   #10
Forgot the pic
Quick & Easy Curb Appeal Jim McClain Project Showcase 78 09-15-2014 02:24 PM
Easy Water conditioning system Pstein Plumbing 4 08-29-2010 07:29 AM
Is there an easy section to cut out one piece of a baseboard? abefroman Remodeling 2 07-28-2010 02:00 PM
Couple of easy (I think) questions... tigereye Electrical 2 03-01-2010 10:33 PM
