Goodman Heat Pump 2 Thermostat Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 12:37 AM   #1
Question
First off, I don't think the wires AT the Goodman PHKJ048-1 Heat Pump are set up correctly to go from the Goodman down to the thermostat. So I would love some help with that...
Once that wiring job is tackled, can somebody tell me how to correctly wire up the RiteTemp 6020 with the jumpers?
I have tried several times today in our lovely 98 degree weather and blew a fuse (I think) because I could get the 3-ton unit to turn on, but it now will not do attempt to start when I turn the Air on. Which reminds me, where is the fuse?
Please see attached photos (if it attaches correctly - It has been that kind of Day!!!)...
Thank you in advance for your help!!!
Goodman Heat Pump 2 Thermostat Wiring-goodmanphkj048-1.jpg   Goodman Heat Pump 2 Thermostat Wiring-ritetemp6020.jpg
RanLoot is offline   Reply With Quote
Old 05-09-2010, 07:20 AM   #2
Electrical Contractor
kbsparky's Avatar
You do not have enough conductors there to properly wire a heat pump unit.
-KB
Tags
goodman ritetemp 6020
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 01:42 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
RTH7500 to Goodman heat pump mrmr56 HVAC 5 11-19-2009 05:47 PM
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 05:34 PM
