-   -   Goodman Heat Pump 2 Thermostat Wiring (http://www.diychatroom.com/f18/goodman-heat-pump-2-thermostat-wiring-70827/)
RanLoot 05-09-2010 01:37 AM
2 Attachment(s)
First off, I don't think the wires AT the Goodman PHKJ048-1 Heat Pump are set up correctly to go from the Goodman down to the thermostat. So I would love some help with that...
Once that wiring job is tackled, can somebody tell me how to correctly wire up the RiteTemp 6020 with the jumpers?
I have tried several times today in our lovely 98 degree weather and blew a fuse (I think) because I could get the 3-ton unit to turn on, but it now will not do attempt to start when I turn the Air on. Which reminds me, where is the fuse?
Please see attached photos (if it attaches correctly - It has been that kind of :censored: Day!!!)...
Thank you in advance for your help!!! :thumbup:
kbsparky 05-09-2010 08:20 AM
You do not have enough conductors there to properly wire a heat pump unit.
