Old 11-30-2011, 02:45 PM   #1
Good wire for bathrooms...
I'm renovating my bathroom and have some Romex 14-2 WG, NM-B. I will be wiring my vanity lights and three switches, a GFI outlet, and a new bath fan.
I've read that I need different wire, that what I have won't work in bathrooms.
Comments...yes, no...what to use. I appreciate any help that I can get in this area.
Thanks, Ed
Ed911 is offline   Reply With Quote
Old 11-30-2011, 03:03 PM   #2
Licensed electrician
The #14 can work for the lighting and fans but cannot be used for the required 20 amp circuit to serve the GFI protected receptacle. You would need #12 for the receptacle circuit.
Old 11-30-2011, 03:14 PM   #3
You need a 20A circuit for the bathroom GFCI (the lights can be on a separate 15A circuit). 14-2 is rated at only 15A. You need 12-2 for the 20A circuit. That being said, NM-B cable should be fine for a bathroom as long as it is properly rated and secured.
clashley is offline   Reply With Quote
The Following User Says Thank You to clashley For This Useful Post:
Ed911 (11-30-2011)
Old 11-30-2011, 04:01 PM   #4
Is there a 11 minute delay between Maryland and Georgia?
just funning.
Old 11-30-2011, 04:03 PM   #5
just funning.
No, just a 15-minute delay between me typing a message and actually clicking "submit."
Old 11-30-2011, 06:56 PM   #6
Thanks for the info...gonna get some 12-2 for the GFI ciruit.
I take it that I'm going to have to run a new line from the box and a 20 amp breaker...12-2 is 20 amp...yes?
I have 5 GFI outlets in my house...and all are on 14-2...hmmm...do they all need to be changed to 12-2.
Thanks again...this forum has been really helpful.
Old 11-30-2011, 06:59 PM   #7
More recent editions of the electrical code have called for 20 amp circuits for bathrooms, kitchen receptacles and laundry receptacles. Before 15 amp circuits were common, but with the increased use of blow dryers and curling irons they become too small.
Yes, #12 for 20 amp circuits.
The code is not retroactive so you can leave the old circuits as is. If you make changes to them you would need to upgrade to the newer standard.
Ed911 (11-30-2011)
Old 11-30-2011, 07:01 PM   #8
Thanks Jim...
I appreaciate your help. I have an electrician friend...and we'll take care of it.
Ed
Old 11-30-2011, 07:06 PM   #9
Electrical Contractor
Originally Posted by Ed911 View Post
Thanks Jim...
Ed
Electricians don't have friends!!!!!!!
What part of NC.
My MIL lives in Whiteville.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 11-30-2011, 07:08 PM   #10
"So I Re-Wired It"
MisterZ's Avatar
its always a good idea to go code+1. IMO, 14 guage wire is too small for anything running 110v
12-2 throughout, and #10 for heavier appliances. also NM is outdated.
good luck with the reno
MisterZ is offline   Reply With Quote
Old 11-30-2011, 07:18 PM   #11
Thanks. Mind telling me what NM stands for and why it's outdated. Just curious. Lowe's sure has a lot of it....lol...
Old 11-30-2011, 07:21 PM   #12
I'm hoping he means mn which has been replace by mn-b
It is the code name for romex(which is a name brand)
The Following User Says Thank You to jbfan For This Useful Post:
MisterZ (11-30-2011)
Old 11-30-2011, 07:27 PM   #13
"So I Re-Wired It"
MisterZ's Avatar
yes, that is what i meant
Old 11-30-2011, 07:44 PM   #14
Non Metalic
Billy_Bob is offline   Reply With Quote
Old 11-30-2011, 08:19 PM   #15
14 gauge is also too small to use on my car battery circuit going to the starter, yet it is only 12 volts. So where can we use 14 gauge?
jlmran is offline   Reply With Quote
which GFCI to buy? mike932 Electrical 138 05-15-2011 05:38 PM
HVAC three wire motor to six wire motor Leo Caproni HVAC 5 10-18-2010 02:23 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
