Good Generator? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 01:19 PM   #1
Rewards Points: 264
Good generator?
What do you guys think of this generator?
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
Probably going to cost about $8,000 total (shipping and customs), then like $500 to rent a forklift to move it.
Does it look like a good generator though? Seem to have all the stuff people try and upcharge for (fuel tank, enclosure, muffler, ect)
Do I just use this wire to hook it up? http://www.ebay.com/itm/0-GAUGE-WIRE...-/280960244729
Do you / should you ground it?
Sorry if my questions are a little basic - I'm hoping it comes with a manual or something. The plan is to run it to a panel box about 10-15 feet away.
tibberous is offline   Reply With Quote
Old 01-16-2013, 01:39 PM   #2
Rewards Points: 746
What are you planning to run?
No on the wire, that junk is for cars.
AandPDan is offline   Reply With Quote
Old 01-16-2013, 02:07 PM   #3
Rewards Points: 264
A GE panel box.
I was afraid of that =/
Is this the kind I need? http://www.ebay.com/itm/250-1-0-awg-...item2320a3abcc
Really expensive - can't find just a 50' length of it.
Old 01-16-2013, 02:17 PM   #4
Rewards Points: 746
GE panel box, OK. What are you trying to run off the panel box. It's way overkill for your house.
What wire depends on how you plan to hook it up. If you're running conduit to it then probably type THWN. Check with your local AHJ.
You'll need 4 wires, the ground can be reduced in size.
Old 01-16-2013, 02:39 PM   #5
Rewards Points: 692
Grounding can be nothing more than a pail of dirt and re-bar with a green wire in an attempt to meet code. but check with your local code gods before adopting this method. This may be an " ILLEGAL " trick.
SeniorSitizen is offline   Reply With Quote
Old 01-16-2013, 02:49 PM   #6
Originally Posted by tibberous View Post
A GE panel box.
Dont forget, when this thing has trouble, and it WILL, SERVICE is what you pay more for when you buy a name brand. The alternator is a Stamford Newage whcih is fine, but not sure what the engine is.
64pvolvo1800 is offline   Reply With Quote
Old 01-16-2013, 02:52 PM   #7
Oso954's Avatar
Rewards Points: 746
A generator of that size is going to consume about 3 gallons an hour at full load. Having enough fuel to run it continuously can be a problem.
This is a Chinese clone of a Perkins diesel. How loud is it ? Even "quieted" a diesel generator can be extremely annoying to your neighbors.
You might want to compare diesel generators to Natural Gas/LP generators.
Oso954 is online now   Reply With Quote
Old 01-16-2013, 03:08 PM   #8
Rewards Points: 264
It seems like NG generators are a little more expensive (both to buy and operate) and don't have the amps to support their watts.
Not really anyone to hear it anyway, and I'm sticking it in a building.
Still not sure what wire to buy. If I want 200amps @ 120vac, do I size the wire for 200amps or 100amps? Isn't it like +120 and -120, so the amps will be split between two wires?
Is the difference between speaker wire, THWN, ect. just the shielding? They have this stuff for cheap but it's aluminum - just don't want it to melt: http://www.ebay.com/itm/250-1-XHHW-A...item2314fddae5
Old 01-16-2013, 03:14 PM   #9
Rewards Points: 746
There's nothing wrong with aluminum in the larger sizes. It's very common.
Yes, it's the shielding that matters - it has to be approved by the NEC. You can't use just any wire.
As to size, let the experts chime in.
Old 01-16-2013, 03:19 PM   #10
Oso954's Avatar
Rewards Points: 746
...and don't have the amps to support their watts.
Old 01-16-2013, 03:33 PM   #11
Several questions arise;
1) NG engine is always cheaper up front.
2) Watts IS amps x volts
3) A 200 Amp service is @-200A 120V legs.
4) Wire rating= # equals conductor size, type letters dictate the insulation and/or application.
5) What purpose is your need? standby or prime power for a shop?
6) If you are putting it in a bldg, you should be careful to be certain you get fresh air IN and hot air and exhasut fumes OUT. Air in should be at least 1.5 times the area of the radiator outlet duct and the outlet should be directed through a duct 1.5 times the surface area as well.
Old 01-16-2013, 05:11 PM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
This whole thread scares me!
Just reading the original post SCREAMS "Hire an electrician!!".
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
diystephen (01-16-2013), electures (01-18-2013), k_buz (01-16-2013)
Old 01-16-2013, 05:12 PM   #13
Customs?
Where do you live?
Old 01-16-2013, 07:00 PM   #14
dmxtothemax's Avatar
Rewards Points: 5,102
It's ok as far as gennys go !
But why do you want one so large ?
Most people would use one much smaller !
dmxtothemax is online now   Reply With Quote
Old 01-16-2013, 07:12 PM   #15
Engineer
Rewards Points: 161
I'm not sure what you mean by the bold. What is the generator for specifically? Has a load calculation been done?
diystephen is offline   Reply With Quote
Champion 7000/9000 Watt Costco Generator wiz561 General DIY Discussions 8 11-24-2012 06:24 PM
Warning Against Doing Dryer Outlet Generator Hookups Arnold Ziffel Electrical 19 11-02-2012 08:11 AM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
Generator and Neutral Bonding Issue bradeng Electrical 6 12-09-2008 11:24 AM
Computer on Generator capt2 Electrical 16 10-23-2008 11:23 AM
