Good Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2012, 04:20 PM   #1
Rewards Points: 186
Good Can Lights
So we're renovating an older 1950s house and we're going to be adding can lights throughout the first floor (ranch style house) and I'm looking for some suggestions for good brands. I've swapped can lights out for the old "boob" lights in our old house, and always used the home depot cheapo brand, but they don't look very nice, and are a bit of a pain to install. So now we need 50 some lights in the new house and I want to do this right the first time. I have full access from the attic, so I'll be using new construction housings, even though it's a bit harder to make cut the holes than retrofit, but I figure I'd do it right since I have access instead of hanging the cans off the drywall.
We had toyed with the idea of dimmable fluorescent based housings, but they're pretty expensive, and I've had good success with just plain old non dimmable CFLs to date. The wife would like dimmer capability in the big living room, so I've found a CFL capable dimmer switch and dimmable bulbs, and people said they had ok success with that, but I'm not sure that works on a 3-way switch, so that might be out of the question. If you know how to get a dimmable fluorescent setup for a 3-way lighting, that also would be appreciated!
Thanks, Bill
Ocelaris is offline   Reply With Quote
Old 11-29-2012, 04:22 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I like Lightolier myself...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Ocelaris (11-29-2012)
Old 11-29-2012, 05:01 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I use nothing but Halo or Juno.
The Following User Says Thank You to k_buz For This Useful Post:
electures (11-29-2012)
Old 11-29-2012, 05:57 PM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Make sure they are airtite if you penetrate the building enevelope.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-29-2012, 07:23 PM   #5
Rewards Points: 186
Thanks, I'll definetly get the airtight ones, as I have a lot of insulating to do up in the attic already, so why make my job harder!
Old 11-30-2012, 12:24 AM   #6
" Euro " electrician
frenchelectrican's Avatar
The most common one I used is either Juno or Halo but from time to time I use the Lightolier but the first two is most used.
Just don't buy off name brand which you will find in Big Box stores.
( many big box store keep one kind of off name brand for while then change to differnt one so find trim and other parts may can be challange so keep it in your mind )
Merci,
Marc
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
wire diagram for pot ceiling lights Dan thehandyman Electrical 12 02-24-2012 10:30 AM
Good recessed lights spring3100 Electrical 2 12-30-2011 07:58 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
