Good 1/2" Corded Drill? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 09:39 AM   #1
Good 1/2" corded drill?
Hi all;
I'm looking for a good all-purpose 1/2" corded drill for 1/2 to 3/4" holes in wood (some through double wall headers).
I am looking to spend between $100 and $150, but after posting in the tools section, got a recommendation of two drills at Amazon.com priced lower than $100.
One is the Milwaukee 0234-6 Magnum with 5.5Amp motor, and the other is a DeWalt DW235G with a 7.8Amp motor. Both cost $90 at Amazon.com.
Am I correct in assuming that more amps is a more powerful drill?
I have always held Milwaukee in high regards as far as quality, but that was a lot of years ago.
I just bought a DeWalt reciprocating saw, and am very happy with it. Seems to be a quality tool.
I figured that since you guys use these tools every day, you would be able to give me some good advice. I'm not a pro, so won't be using mine every day, or even every week, but still, I want something that will not complain when doing a tough job here and there.
Any suggestions?
FW
fw2007 is offline   Reply With Quote
Old 08-04-2008, 10:06 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You are correct about the amps. I would go with the Dewalt. I drill a lot of studs and joists and more power is a good thing. Milwaukee is still a good quality tool. Just be careful with your wrists in case of a jam. It can hurt.
John
jrclen is offline   Reply With Quote
Old 08-04-2008, 11:40 AM   #3
Thanks for the advice.
The DeWalt DW235G comes with a 360 grip that should help keep it stable.
Variable speed helps as well. Can't imagine doing without, but back when I got my first power drill, it didn't have variable speed! Guess I'm giving away my age again
FW
Old 08-04-2008, 01:41 PM   #4
Rewards Points: 338
fw2007, I had a Dewalt for many years and have recently switched to a Bosch (after the Dewalt died). So far I like the Bosch better, but I'll need to drill more holes to judge. I would also spend a little more and get a 1/2" hammer drill. You may not need to use the hammer function all the time, but it's nice to have.
petey_c is offline   Reply With Quote
Old 08-04-2008, 03:34 PM   #5
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
If you want a good hammer drill I hear Hilti is very good.
Pudge565 is offline   Reply With Quote
Old 08-04-2008, 05:27 PM   #6
Rewards Points: 392
Hilti is as good as it can get for power tools, although expensive.
rustyjames is offline   Reply With Quote
Old 08-04-2008, 06:26 PM   #7
jrclen's Avatar
Rewards Points: 514
I hear you. Same here. My first power drill didn't even have reverse.
John
Old 08-04-2008, 08:03 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
I commend you for wanting buy a REAL drill.
It's not always about the bottom line. Sometimes (always IMO) quality is worth more than saving a few dollars.
Old 08-04-2008, 08:53 PM   #9
jrclen's Avatar
Rewards Points: 514
Petey must have heard about me. My Milwaukee finally quit after many years. Right in the middle of a job 30 miles from home/shop. I ran from the job site to a nearby Walmart and bought the heavy duty B & D. Great price too. The gears went out on the second house it worked on. Not such a great price after all.
John
Old 08-04-2008, 09:04 PM   #10
Does B&D make anything worth buying anymore?
I think my first power drill was a B&D, and it lasted a long time. No variable speed, and no reverse, and I believe only 1/4" chuck.
FW
Old 08-04-2008, 10:43 PM   #11
Idiot Emeritus
Rewards Points: 1,492
Look at the RPMs as well. An 8 amp drill that runs at 2000 RPM will not have as much torque as a 5 amp one at 500 RPM.
For a 3/4" auger bit I'd go for about 500-1000 RPM. The slower it is, the more likely it is to break your wrist, the faster it is the more likely it is to stall when the bit hits a knot.
Rob
micromind is offline   Reply With Quote
Old 08-05-2008, 09:55 AM   #12
jrclen's Avatar
Rewards Points: 514
FW
I'm sorry to say I don't believe they do. Many of my home power tools back in the old days were B&D and a few are still around. But recently they have ditched quality for cheap. But that drill I bought would have lasted a homeowner 20 years with the number of holes I bored, spread out over that time frame.
John
Old 08-05-2008, 07:21 PM   #13
Res Ipsa Loquitur
FW
Mine was like that- gray and metal case, 1/4" chuck, one speed- ON. I think it was about $12.00.
I think B&D now makes tools like Warmart makes toasters. Cheap for the masses. That is why they have a Dewalt division. Same goes for Skil with their cheap lines- they seem to put all their engineering skill into the Bosch division.
I like my Milwaukee Magnum 1/2" for heavy drilling- Sure battery tools seem to be the trend but the batts always need to be charged.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Trim Tramp : Good or Bad? KUIPORNG Carpentry 16 09-10-2013 11:54 AM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Good inexpensive 10" miter saw for a DIY'ER??/ Sellncars Tools 19 09-26-2006 01:17 PM
